I’m actually trying to do this in a blueprint, so that might change the answer…
TL;DR How can I remove a dependency on an input_boolean
for a condition when the input_boolean
state is determined by an event that is not the trigger event.
Problem: I want to prevent an automation (motion detection triggering light to turn on) from running for X min after a given event has been fired (light switch turned off). The event is a switch press for a Deconz switch, that can only be checked via listening for the deconz_event
event.
The issue I’m facing is, I only seems to be able to use event data in a condition, if the event was part of a trigger
for the automation (using trigger.event.xxx
). However, my trigger is a motion sensor and not the light switch.
I have previously got around this by having the light switch event toggle an input_boolean
and then my automation checks the state of the input_boolean
in the condition
section. This doesn’t scale for my blueprint, as I’d need to create a new input_boolean
for every instance of the blueprint or else share state between instances, neither of which are suitable.
I can see the deconz_event
in question has an attribute time_fired
that is an ISO format date, so I thought if I could grab that and compare the current date/time, it might be a handle to use in a condition. But I can’t work out how to read that attribute (*see next comment).
The other option might be to add the light switch event as an additional trigger and then do some magic to prevent the action
from running in some way… Not sure how this would work, if at all.
Thanks in advanced.
