Trying to clear notification on automations
Back story. Been using HA for a long time and I generally keep up pretty well.
I have an enormous configuration.yaml and anyone who looked at it would realize it isn’t very intuitive or in a logical order. That being said…everything works and it works good.
I recently went from 110 to 114.4 and it kind of broke my interface. Rather than restore a backup I decided to push through, and painstaking went through LoveLace UI. Everything is just how I like it and I’m back in full business. Even took a snapshot and restored it to a clean installation of HA.
I had a massive notification list of things that couldn’t be loaded (old groups mostly) and I went through configuration.yaml and removed them all. I still get a notification for automation though. In the configuration.yaml fileI have 33 automations and they look like what is below. I cropped it off at two just so you can see the formatting.
All automations WORK however I’m just now trying to clear the notification on boot that automation won’t load or something like that.
Do I have to move it to automations.yaml and no longer number them?
config below:
automation:
  alias: Turn on lights when sun sets
    - platform: sun
      event: sunset
      offset: '+00:15:00'
    - service: switch.turn_on
      entity_id: switch.ge_12722_on_off_relay_switch_switch_3
    - service: light.turn_on
      entity_id: light.living_room_lamp
      entity_id: switch.jasco_products_14291_in_wall_smart_switch_switch
      entity_id: switch.front_window_outlet
automation 2:
  alias: Turn off lights when sun rises
    - platform: sun
      event: sunrise
      offset: '-00:30:00'
    - service: switch.turn_off
    - service: light.turn_off
automation 3:
No clue if that’s the issue, but why don’t you write them this way?
automation:
  - alias: Turn on lights when sun sets
  - alias: Turn off lights when sun rises
