Trying to convert min to hh:mm:ss
hi, the road was long to make my card work, it now does, but I want better results.
my lawn mower gives total blades on time entity, in minutes, it now outputs 19240 somtehing, as I wanted as output the total number of minutes by day I created, with help of forum users a utility meter helper wich works but still outputting minutes, now what I want is minutes as hh:mm:ss, for that I created a sensor template
{% set minutos = states('sensor.tiempo_total_cuchillas_dolly')  %}
{% set tiempo = timedelta(minutes=minutos) %}
{{ tiempo }}
now the problem is that the sensor template is as unavailable
is the entity created when the utility meter helper was used.
any suggestion?
{% set minutos = states('sensor.tiempo_total_cuchillas_dolly') | float(0) %}
thanks, I`ll try, could you explain why is that?
Don’t include a state class, it should be none
not available and if I enter there is some message too
