Hi All
I have a SHP-7 here that I’m trying to set up with esphome.
If I look at the Tasmota template repository, I get this pinout for SHP-7:
So by modifying the SHP-6 esphome config, I got this:
substitutions:
device_name: doubleplug
# Higher value gives lower watt readout
current_res: '0.00025'
# Lower value gives lower voltage readout
voltage_div: '940'
esphome:
platform: ESP8266
board: esp8285
on_boot:
then:
- switch.turn_on: relay1
- switch.turn_on: relay2
wifi:
ssid: !secret wifissid
password: !secret wifipw
reboot_timeout: 60min
manual_ip:
static_ip: 10.11.13.43
gateway: 10.11.13.1
subnet: 255.255.255.0
# use_address: 10.11.12.201
fast_connect: true
ap:
ssid: "${device_name} Hotspot"
password: !secret appw
logger:
baud_rate: 0
web_server:
port: 80
auth:
username: !secret webuser
password: !secret webpw
api:
ota:
password: !secret otapw
time:
- platform: homeassistant
text_sensor:
- platform: version
name: "${device_name} ESPHome Version"
- platform: wifi_info
ip_address:
ssid:
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO00
on_press:
- switch.toggle: relay1
- platform: gpio
internal: true
pin:
number: GPIO12
on_press:
- switch.toggle: relay2
output:
- platform: gpio
pin: GPIO13
inverted: true
- platform: gpio
pin: GPIO02
inverted: true
switch:
- platform: gpio
pin: GPIO14
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- output.turn_on: led1
on_turn_off:
- output.turn_off: led1
- platform: gpio
pin: GPIO16
on_turn_on:
- output.turn_on: led2
on_turn_off:
- output.turn_off: led2
status_led:
pin:
number: GPIO02
inverted: true
- platform: wifi_signal
name: '${device_name} wifi signal'
update_interval: 60s
accuracy_decimals: 0
- platform: uptime
unit_of_measurement: days
update_interval: 300s
accuracy_decimals: 1
filters:
- multiply: 0.000011574
- platform: hlw8012
sel_pin:
number: GPIO03
inverted: true
cf_pin: GPIO04
cf1_pin: GPIO05
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: 'A'
accuracy_decimals: 3
icon: mdi:flash-outline
voltage:
unit_of_measurement: 'V'
power:
unit_of_measurement: 'kW'
accuracy_decimals: 5
filters:
- multiply: 0.001
change_mode_every: 4
update_interval: 10s
- platform: total_daily_energy
name: '${device_name} daily energy'
power_id: power
unit_of_measurement: kWh
The relays are shown in HA, and I can turn them on and off from HA.
What does not work yet:
LED2 doesn’t turn on / off with the relay.
BUTTON1 doesn’t trigger the RELAY1
BUTTON2 doesn’t trigger the RELAY2
It reads out powerconsumption, though I’m not sure if the chip I put in the config is the right one?
Any ideas on what I did wrong here, it did work work with tasmota?
