Trying to create Aux_Heat Button or Switch
I have just installed a Hive Thermostat and I’m trying to break out out the Aux_Heat toggle switch from the Hot Water card and make into a switch so it can be seen by Homekit.
Aux Heat works fine via the toggle switch in the card.
I have tried the following code to try to break this toggle out but it doesn’t do anything:
  switches:
    water_boost:
      value_template: "{{is_state_attr('climate.hot_water', 'aux_heat', 'off') }}"
      turn_on:
        service: climate.set_aux_heat
          entity_id: climate.hot_water
          aux_heat: true
      turn_off:
          aux_heat: false
I have also just tried creating an entity button in Lovelace but i get an error "failed to call service/climate.set aux_heat
Can anyone please advise, its driving me mad
Ignore this it seems to be working now! Not sure why it wasn’t before.
