SOLVED: Trying to define one of the outputs of a SHP7 (dual socket) as a light
I have this working as two switches, but I’m trying redefine one of the outputs as a light instead of a switch.
I’ve built this:
substitutions:
  device_name: serverroompower
  # Higher value gives lower watt readout
  current_res: '0.002291'
  # Lower value gives lower voltage readout
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    then:
      - switch.turn_on: relay1
#      - switch.turn_on: relay2
wifi:
  ssid: !secret wifissid
  password: !secret wifipw
#  reboot_timeout: 60min
  manual_ip:
    static_ip: 10.11.13.43
    gateway: 10.11.13.1
    subnet: 255.255.255.0
#  use_address: 10.11.12.201
  fast_connect: true
  ap:
    ssid: "${device_name} Hotspot"
    password: !secret appw
logger:
  baud_rate: 0
web_server:
  port: 80
  auth:
    username: !secret webuser
    password: !secret webpw
api:
ota:
  password: !secret otapw
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: "${device_name} ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO0
    on_press:
      - switch.toggle: relay1
  - platform: gpio
    internal: true
    pin:
      number: GPIO15
    on_press:
      - light.toggle: relay2
output:
  - platform: esp8266_pwm
    pin:
      number: GPIO13
      inverted: true
    pin:
      number: GPIO2
      inverted: true
    pin: GPIO16
switch:
  - platform: gpio
    pin: GPIO14
    on_turn_on:
      - output.turn_on: led1
    on_turn_off:
      - output.turn_off: led1
light:
  - platform: binary
    output: relay2
status_led:
  pin:
    number: GPIO01
    inverted: true
  - platform: wifi_signal
    name: '${device_name} wifi signal'
    update_interval: 60s
    accuracy_decimals: 0
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
  - platform: hlw8012
    sel_pin:
      number: GPIO03
      inverted: true
    cf_pin: GPIO04
    cf1_pin: GPIO05
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    current:
      unit_of_measurement: 'A'
      accuracy_decimals: 3
      icon: mdi:flash-outline
    voltage:
      unit_of_measurement: 'V'
    power:
      unit_of_measurement: 'kW'
      filters:
        - multiply: 0.001
    change_mode_every: 4
    update_interval: 10s
  - platform: total_daily_energy
    name: '${device_name} daily energy'
    power_id: power
    unit_of_measurement: kWh
    accuracy_decimals: 5
But I get an error:
ID ‘relay2’ of type esp8266_pwm: :ESP8266PWM doesn’t inherit from light::LightState. Please double check your ID is pinting to the correct value.
I don’t understand how to solve that?
The id relay2 refers to the pwm pin defined here, not the light entity you want.
    pin: GPIO16
Change the id by appending _pin:
output:
    pin: GPIO16
light:
  - platform: binary
    output: relay2_pin
I actualy got it fixed, but had to go to 1.16.0-dev
Here is 1 output set up as a switch and the other is set up as a light (it’s a dualoutput plug).
substitutions:
  voltage_div: '940'
  # BW-SHP7, dual outlet with powermonitoring.
  # One button for each relay, and one red led for each relay, as well as a blue status led
  # Static IP is configured, and fast_connect is enabled, as the SSID is hidden
  # Webserver is active and pw protected, and the OTA is password protected
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    then:
wifi:
  manual_ip:
    gateway: 10.11.13.1
  fast_connect: true
  ap:
logger:
  baud_rate: 0
web_server:
  port: 80
  auth:
api:
ota:
time:
text_sensor:
  - platform: version
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: true
    on_press:
  - platform: gpio
    internal: true
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
      inverted: true
    on_press:
output:
    pin:
      number: GPIO13
      inverted: true
    pin:
      number: GPIO2
      inverted: true
  - platform: gpio
    pin: GPIO16
switch:
  - platform: gpio
    pin: GPIO14
    on_turn_on:
    on_turn_off:
light:
  - platform: binary
    output: light_relay
    on_turn_on:
      - output.turn_on: led2
    on_turn_off:
      - output.turn_off: led2
status_led:
  pin:
    number: GPIO01
    inverted: true
  - platform: uptime
    filters:
  - platform: hlw8012
    sel_pin:
      number: GPIO03
      inverted: true
    cf_pin: GPIO04
    cf1_pin: GPIO05
    current:
    voltage:
    power:
      filters:
        - multiply: 0.001
    power_id: power
