I am trying to get a custom package scraper I made to work. It works on local windows direct call, but I use HA OS. I tried remaking it in pyscript HACS edition, but 2 days and nothing later, gave up. I read that AppDaemon is designed for this type of complex stuff, so I am trying to remake it in that. No errors so far, but home assistant does not see the service hooks, so I cannot test it.
Any help would be greatly appreciated. Code below.
import imaplib
import email
import json
import requests
from datetime import datetime
from email.header import decode_header
from email.utils import parsedate_to_datetime
from openai import OpenAI
from bs4 import BeautifulSoup
import regex as re
import os
import time
import barcode
from barcode.writer import ImageWriter
import appdaemon.plugins.hass.hassapi as hass
class PackageScraper(hass.Hass):
# File to store the last scan date
BASE_DIR = "/addon_configs/a0d7b954_appdaemon/apps/package_scraper/files"
LAST_SCAN_FILE = "last_scan_date.txt"
def initialize(self):
Initializes the app and listens for service calls.
# Listen for the run scraper service call
self.listen_event(self.run_scraper, "package_scraper.run")
# Listen for the manual delivered service call
self.listen_event(self.mark_delivered, "package_scraper.manual_delivered")
def resolve_path(self, filename):
Resolves a file path within the BASE_DIR.
return os.path.join(self.BASE_DIR, filename)
# Function to read credentials from secrets.txt
def read_credentials(self, filename):
file_path = self.resolve_path(filename)
with open(file_path, 'r') as file:
lines = file.readlines()
username = lines[0].strip()
password = lines[1].strip()
openai_org = lines[2].strip()
openai_project = lines[3].strip()
api_key = lines[4].strip()
parcel_key = lines[5].strip()
postal_code = lines[6].strip()
return username, password, openai_org, openai_project, api_key,parcel_key,postal_code
# Function to connect to the IMAP server
def connect_to_email_server(self,server, username, password):
try:
mail = imaplib.IMAP4_SSL(server)
mail.login(username, password)
return mail
except Exception as e:
print(f"Failed to connect to the email server: {e}")
return None
# Function to get the last scan date
def get_last_scan_date(self,):
"""Retrieve the last scan date from the file."""
if os.path.exists(file_path):
with open(file_path, "r") as file:
date_str = file.readline().strip()
try:
return datetime.fromisoformat(date_str)
print(f"Error parsing last scan date: {e}")
return None
return None
# Function to save the last scan date
def save_last_scan_date(self,date):
"""Save the last scan date to the file."""
with open(file_path, "w") as file:
file.write(date.isoformat())
# Function to fetch email IDs from the inbox
def fetch_email_ids(self,mail, folder="inbox", scan_all=False):
Fetch email IDs from the inbox.
If scan_all is False, only fetch emails with a date greater than the last scan date.
try:
mail.select(folder)
status, messages = mail.search(None, 'ALL')
if status != "OK":
print("No messages found!")
return []
email_ids = messages[0].split()
print(f"Found {len(email_ids)} emails.")
if scan_all:
print("returning all email ids")
return email_ids
# Retrieve emails with a date greater than the last scan date
last_scan_date = self.get_last_scan_date()
if last_scan_date is None:
return email_ids # No prior scan date, process all emails
filtered_ids = []
for i in reversed(range(len(email_ids))):
email_id = email_ids[i]
print(f"checking: {i}")
status, msg_data = mail.fetch(email_id, '(BODY.PEEK[HEADER.FIELDS (DATE)])')
if status != "OK":
print(f"Failed to fetch email date for ID {email_id}")
continue
for response_part in msg_data:
if isinstance(response_part, tuple):
msg_date = email.message_from_bytes(response_part[1]).get("Date")
if msg_date:
try:
email_date = parsedate_to_datetime(msg_date)
if email_date <= last_scan_date:
print("Encountered email older than last scan date. Stopping.")
return filtered_ids # Stop processing earlier emails
filtered_ids.append(email_id)
print(f"Error parsing email date: {e}")
return filtered_ids
print(f"Failed to fetch email IDs: {e}")
return []
# Function to fetch and process a single email
def process_email(self,mail, email_id, openai_client):
Process a single email and extract order and shipping details.
try:
email_data = self.fetch_and_parse_email(mail, email_id)
if not email_data:
return None
# Ignore specific senders (e.g., PayPal)
if any(domain in email_data.get("from", "").lower() for domain in ["amazon.com", "amazon.ca","paypal.com"]):
print(f"Ignored email from {email_data['from']}")
return None
# Extract order and shipping information using GPT
parsed_data = self.extract_with_gpt(email_data, openai_client)
if not parsed_data or "order_number" not in parsed_data:
print(f"Skipped email: No order number found for email ID {email_id}")
return None
# Merge extracted data into email_data
email_data.update(parsed_data)
return email_data
print(f"Failed to process email ID {email_id}: {e}")
return None
def fetch_and_parse_email(self,mail, email_id):
Fetch and parse an email by ID.
try:
status, msg_data = mail.fetch(email_id, '(RFC822)')
if status != "OK":
print(f"Failed to fetch email ID {email_id}")
return None
msg = email.message_from_bytes(response_part[1])
# Extract headers
subject, encoding = decode_header(msg.get("Subject", ""))[0]
subject = subject.decode(encoding if encoding else "utf-8") if isinstance(subject, bytes) else subject
email_from = msg.get("From")
date_received = self.parse_email_date(msg.get("Date"))
# Extract body
body = self.extract_email_body(msg)
cleaned_body = self.clean_email_body(body)
return {
"subject": subject,
"from": email_from,
"date_received": date_received,
"body": cleaned_body,
print(f"Error fetching or parsing email ID {email_id}: {e}")
return None
def parse_email_date(self,date_header):
Parse the email date header into ISO format.
try:
if date_header:
return parsedate_to_datetime(date_header).isoformat()
return None
# Function to extract the email body
def extract_email_body(self,msg):
body = ""
try:
if msg.is_multipart():
for part in msg.walk():
if part.get_content_type() in ["text/plain", "text/html"]:
body += part.get_payload(decode=True).decode("utf-8", "ignore")
else:
body = msg.get_payload(decode=True).decode()
print(f"Could not decode email body: {e}")
return body
# Function to clean the email body
def clean_email_body(self,body):
try:
soup = BeautifulSoup(body, "html.parser")
# Remove script and style elements
for element in soup(["script", "style"]):
element.decompose()
text = soup.get_text()
text = re.sub(r"\{(?:[^{}]*|(?R))*\}", "", text) # Remove nested CSS
text = re.sub(r"[^\x20-\x7E\n]", "", text).strip()
text = re.sub(r"\n{2,}", "\n", text) # Normalize newlines
return text
print(f"Error cleaning email body: {e}")
return ""
# Function to process GPT response
def extract_with_gpt(self,email_data, openai_client):
Use GPT to extract order and shipping details from the email.
Includes logic to handle Amazon-specific emails and parse their statuses.
try:
prompt = f"""
Extract the order number, tracking/shipping number, company, and list of items in shipment from the following email.
Provide the output as a JSON object with the keys: order_number, tracking_number, company, status, delivery_date, and items.
Carriers such as Canada Post are not the company; for example, Amazon is the company. Only return the json, do not describe it
Email Data:
Subject: {email_data['subject']}
Body: {email_data['body']}
completion = openai_client.chat.completions.create(
model="gpt-4o",
messages=[
{"role": "system", "content": "You are a helpful assistant."},
{"role": "user", "content": prompt}
response = completion.choices[0].message.content
return self.process_gpt_response(response)
print(f"Error during GPT extraction: {e}")
return {
"order_number": None,
"tracking_number": None,
"status": None,
"delivery_date": None,
"items": [],
# Function to handle GPT response
def process_gpt_response(self,response):
try:
cleaned_response = response.replace('```json\n', '').replace('```', '')
parsed_json = json.loads(cleaned_response)
if not parsed_json.get("order_number"):
return {} # Skip if no order number
return parsed_json
print(f"Failed to process GPT response: {e}")
return {}
def fetch_and_save_email_ids(self,folder="inbox", scan_all=False):
Fetch email IDs based on the folder and scan mode and save them to a file.
username, password, _, _, _,_,_ = self.read_credentials("secrets.txt")
mail = self.connect_to_email_server("imap.gmail.com", username, password)
if mail is None:
return
try:
email_ids = self.fetch_email_ids(mail, folder, scan_all)
print(f"Fetched {len(email_ids)} email IDs.")
file_path = self.resolve_path("email_ids.txt")
for email_id in email_ids:
file.write(f"{email_id.decode()}\n") # Save as string
finally:
mail.logout()
def process_and_save_emails(self,openai_client, folder="inbox"):
Process emails based on saved email IDs and merge the results with existing JSON data.
Updates the last scan date if successful.
if mail is None:
return
mail.select(folder)
if status != "OK":
return
try:
# Read email IDs from file
try:
email_ids = [line.strip() for line in file.readlines()]
except FileNotFoundError:
print("No email IDs file found.")
return
# Load existing emails from JSON file
file_path = self.resolve_path("emails.json")
with open(file_path, "r", encoding="utf-8") as file:
existing_emails = json.load(file)
else:
existing_emails = []
# Create a lookup dictionary for existing emails by order_number
existing_emails_dict = {
email.get("order_number"): email
for email in existing_emails
if email.get("order_number")
# Process new emails and merge data
new_emails = []
for email_id in reversed(email_ids):
email_data = self.process_email(mail, email_id.encode(), openai_client)
if email_data:
order_number = email_data.get("order_number")
if order_number:
# Update existing entry or add a new one
if order_number in existing_emails_dict:
existing_emails_dict[order_number].update(email_data)
else:
existing_emails_dict[order_number] = email_data
else:
# Skip emails without an order_number
new_emails.append(email_data)
if new_emails:
# Save merged emails to JSON
merged_emails = list(existing_emails_dict.values())
with open(file_path, "w", encoding="utf-8") as file:
json.dump(merged_emails, file, indent=4, ensure_ascii=False)
# Update the last scan date
latest_date = max(
datetime.fromisoformat(email["date_received"])
for email in new_emails
if "date_received" in email
self.save_last_scan_date(latest_date)
finally:
mail.logout()
def update_package_status(self,api_key,postal_code):
Check the status of packages using the Ship24 API.
Updates the email data with the tracking status and returns a list of delivered packages.
delivered_packages = []
tracking_url = 'https://parcelsapp.com/api/v3/shipments/tracking'
try:
# Load the saved emails
# Create a lookup dictionary by order_number for efficient updates
email_lookup = {email.get("order_number"): email for email in emails if email.get("order_number")}
# Collect packages to track
shipments = [
"trackingId": email["tracking_number"],
"language": "en",
"country": "Canada",
"zipcode": postal_code
for email in emails
if "tracking_number" in email
and email["tracking_number"]
and email.get("status") not in {"delivered","archive"}
print(f"Tracking {len(shipments)} shipments.")
if not shipments:
print("No packages to track.")
return []
# Initiate tracking request
response = requests.post(
tracking_url, json={"apiKey": api_key, "shipments": shipments}
if response.status_code == 200:
json_response = response.json()
# Check for shipments in the initial response
cached_shipments = []
if "shipments" in json_response:
cached_shipments = json_response.get("shipments", [])
# Get UUID from response
uuid = response.json().get("uuid")
polled_shipments = []
if uuid:
# Poll tracking status using UUID
def poll_tracking_status():
while True:
status_response = requests.get(tracking_url, params={"uuid": uuid, "apiKey": api_key})
if status_response.status_code == 200:
status_data = status_response.json()
# Check if all tracking is done
if status_data.get("done", False):
return status_data.get("shipments", [])
else:
print("Tracking in progress... Retrying in 10 seconds.")
time.sleep(10)
else:
print(f"Error polling tracking status: {status_response.text}")
break
return []
# Fetch the shipments from polling
polled_shipments = poll_tracking_status()
for shipment in cached_shipments + polled_shipments:
tracking_number = shipment.get("trackingId")
status = shipment.get("status", "Unknown")
delivered_by = shipment.get("delivered_by", None)
# Update the corresponding email by order_number
for email in emails:
if email.get("tracking_number") == tracking_number:
email["status"] = status
email["delivered_by"] = delivered_by
if status.lower() == "pickup":
generate_barcode(tracking_number)
emailer.send_email( "Package ready for pickup",
f"Package with tracking number {tracking_number} is ready for pickup",
"[email protected]",
tracking_number = tracking_number
# Check if status changed to delivered
if status.lower() == "delivered" and email not in delivered_packages:
emailer.send_email("Package Delivered", f"Package with tracking number {tracking_number} has been delivered", "[email protected]")
print(f"Package {tracking_number} marked as delivered.")
# Save updated emails back to the JSON file
updated_emails = list(email_lookup.values())
json.dump(updated_emails, file, indent=4)
print(f"Error checking package status: {e}")
def filter_and_save_tracking_emails(self,input_file, output_file):
Filters emails with valid tracking numbers and undelivered statuses.
Saves the filtered emails to a new file for tracking purposes.
try:
file_path = self.resolve_path(input_file)
# Filter emails based on tracking number and undelivered status
filtered_emails = [
if str(email.get("status", "")).lower() not in {"delivered", "archive"}
# Save the filtered emails to the output file
file_path = self.resolve_path(output_file)
json.dump(filtered_emails, file, indent=4)
print(f"Filtered {len(filtered_emails)} emails for tracking and saved to {output_file}.")
print(f"Error filtering and saving tracking emails: {e}")
def manually_update_delivery_status(self):
Interactive terminal command to manually update delivery status.
Goes through each email in emails_to_watch.json and updates emails.json.
try:
# Load emails to watch
file_path = self.resolve_path("emails_to_watch.json")
emails_to_watch = json.load(file)
# Create a lookup dictionary for emails by order_number
email_dict = {email.get("order_number"): email for email in emails if "order_number" in email}
updated_emails_to_watch = []
# Iterate through emails to watch
for email in emails_to_watch:
order_number = email.get("order_number")
tracking_number = email.get("tracking_number", "N/A")
latest_event = email.get("latest_event", {}).get("status", "No recent events")
subject = email.get("subject", "No subject")
sender = email.get("from", "No from available")
print(f"Order Number: {order_number}")
print(f"Tracking Number: {tracking_number}")
print(f"Latest Event: {latest_event}")
print(f"Subject: {subject}")
print(f"from: {sender}")
print("=" * 50)
delivered = input("Is this package delivered? (y/n): ").strip().lower()
if delivered == "y":
# Update status to delivered
if order_number in email_dict:
email_dict[order_number]["status"] = "Delivered"
print(f"Marked order {order_number} as delivered.")
# Also update the email in emails_to_watch.json
email["status"] = "delivered"
else:
print(f"Order number {order_number} not found in emails.json.")
elif delivered == "n":
print(f"Order {order_number} not marked as delivered.")
else:
print("Invalid input. Skipping...")
# Append to updated list of emails to watch if not delivered
if str(email.get("status", "")).lower() != "delivered":
updated_emails_to_watch.append(email)
# Save updated emails back to emails.json
json.dump(list(email_dict.values()), file, indent=4)
print("Emails updated successfully.")
# Save updated emails to watch back to emails_to_watch.json
json.dump(updated_emails_to_watch, file, indent=4)
print("Emails_to_watch.json updated successfully.")
except FileNotFoundError as e:
print(f"Error: {e}")
print("Make sure 'emails_to_watch.json' and 'emails.json' exist.")
print(f"An unexpected error occurred: {e}")
def mark_delivered(self, event, data, kvargs):
order_id = data.get("order_id")
if not order_id:
return
self.log(f"marking order id {order_id} as delivered")
updated = False
if email.get("order_number") == order_id:
updated = True
break
if updated:
self.log(f"Order ID {order_id} marked as delivered.")
else:
self.log(f"Order ID {order_id} not found.")
def run_scraper(self, event, data, kvargs):
# Run the email fetching and processing
self.fetch_and_save_email_ids(folder="\"Online Purchases\"", scan_all=False)
# Create the OpenAI client for processing
_, _, openai_org, openai_project, api_key, _,_ = self.read_credentials("secrets.txt")
openai_client = OpenAI(organization=openai_org, project=openai_project, api_key=api_key)
self.process_and_save_emails(openai_client, folder="\"Online Purchases\"")
_, _, _, _, _, parcel_key,postal_code = self.read_credentials("secrets.txt")
self.update_package_status(parcel_key,postal_code)
self.filter_and_save_tracking_emails("emails.json", "emails_to_watch.json")
#self.manually_update_delivery_status()
