SELECT table_schema “database”, Round(Sum(data_length + index_length) / 1024 / 1024, 1) “value” FROM information_schema.tables WHERE table_schema=“hass” GROUP BY table_schema LIMIT 1; returned no results
This is the sensor configuration:
- platform: sql
db_url: !secret url_mysql
scan_interval: 3600
queries:
- name: db_size
query: 'SELECT table_schema "database", Round(Sum(data_length + index_length) / 1024 / 1024, 1) "value" FROM information_schema.tables WHERE table_schema="hass" GROUP BY table_schema;'
column: 'value'
unit_of_measurement: MB
The recorder component is working great with the same db_url.
Hi, if like me you followed the example from the mariadb addon page for hass.io to create your DB, you will need to change the table_schema=“hass” to table_schema=“homeassistant” in your SQL.
I had the exact same problem until I noticed it was trying to pull info for the wrong DB name.
- platform: sql
db_url: !secret mysql_url
icon: mdi:database
queries:
- name: HASS DB size
query: 'SELECT table_schema "database", Round(Sum(data_length + index_length) / 1048576, 2) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema;'
column: 'value'
I am running the mariadb addon
i will get time but show unknow
SELECT TIMEDIFF(created , last_changed) AS ActiveTime FROM homeassistant.states WHERE entity_id = 'vacuum.living_room_vacuum' AND state = 'cleaning' GROUP BY HOUR(created) ORDER BY state_id DESC LIMIT 0 , 1;
