I am trying to install a Razberry2 Zwave hat on HAOS. I cant figure out how to disable bluetooth. I can disable it via the GUI in HA but from what i am reading i have to disable it via the config.txt file. I have been at it for 6 hours and im lost.
I think the problem might be the location of the config file. I have tried advanced ssh/terminal as well as every other possible way imaginable. Using the commands in may of these posts just doesnt work.
I did get into the linux files on the SD card and the config file is in a folder called Fat16 Volume 1 (hassos-boot). But again, i cant find a way to edit it. The program i am using to see the files is called diskinternals on Windows.
Changing the PI config is something that HAOS doesn’t really allow. If you do find a way to change it chances are that it will be changed back the next time you update HAOS…
If you still want to use that special hardware look into the more advanced ‘container’ style install with which you retain access to the OS.
The manufacturer says bluetooth needs to be disabled. I am using diskinternals to see the config file. It doesnt appear using my mac or windows without special software.
