Trying to install ESPresense on a ESP32
I have tried to install ESPresense onto a ESP32, I flashed it and that was fine and I tried to set it up to my wifi which didn’t work and I tried to find a way to do it for 30 minutes. It finally worked when I connected my laptop to the board and opened the temporary SSID to take me to the configuration website. Once I had set it up to my wifi I then tried to connect it to MQTT and run it. It saved and then would not show up in my MQTT service on HA under entitiies, I checked the logs of the device and it kept disconnecting from MQTT reason 0 and would reconnect and then disconnect and I couldn’t get it past there. Any help would be great if you need any more information I’d be happy to provide.
Hi, welcome to the forum @channa
This is not the espresence forum. Espresence is a project completely independent of home assistant, although can be used with home assistant.
Someone here may be able to help, but you may be better going to the espresence support channels.
