I’m trying to isolate the slow loading of my history and logbook, I am not sure I understand the log information I am reading.
Host system is on a server running Linux KVM/Qemu - 6c/12t CPU Xeon E-2176G @ 3.70GHz; 64GB RAM
HassOS VM has 4 CPU cores, 2GB RAM, 100GB disk (backed by RAID1 7200RPM WD-Red drives)
I’m already using MariaDB (addon) and that helped a lot vs SQLite but when the SQLite DB got big I enlarged my disk and now it’s too big for going back to a SSD so I may be getting a performance hit on that but I don’t think it should be THAT bad.
My configuration:
recorder:
db_url: mysql://user:password@core-mariadb/homeassistant?charset=utf8
purge_keep_days: 21
# purge_interval: 1
exclude:
domains:
# - automation
- device_tracker
entities:
- sensor.time
- sensor.date
- sensor.date_time
history:
exclude:
domains:
- automation
MariaDB looks like it’s not using much memory
My logfile showing load times:
The logfile while pulling up a view with a couple dozen 24-hour graphs (temp and humidity of all rooms and inside/outside)
2021-02-09 22:28:41 DEBUG (SyncWorker_45) [homeassistant.components.recorder.util] querying 4011 rows took 3.120492s
2021-02-09 22:28:41 DEBUG (SyncWorker_45) [homeassistant.components.history] get_significant_states took 3.120681s
2021-02-09 22:28:42 DEBUG (SyncWorker_10) [homeassistant.components.recorder.util] querying 7200 rows took 3.784467s
2021-02-09 22:28:42 DEBUG (SyncWorker_10) [homeassistant.components.history] get_significant_states took 3.784633s
2021-02-09 22:28:42 DEBUG (SyncWorker_17) [homeassistant.components.recorder.util] querying 5991 rows took 3.857610s
2021-02-09 22:28:42 DEBUG (SyncWorker_17) [homeassistant.components.history] get_significant_states took 3.857728s
2021-02-09 22:28:44 DEBUG (SyncWorker_36) [homeassistant.components.recorder.util] querying 8816 rows took 5.305845s
2021-02-09 22:28:44 DEBUG (SyncWorker_36) [homeassistant.components.history] get_significant_states took 5.305992s
2021-02-09 22:28:50 DEBUG (SyncWorker_45) [homeassistant.components.recorder.util] querying 13 rows took 8.763604s
2021-02-09 22:28:50 DEBUG (SyncWorker_45) [homeassistant.components.history] getting 13 first datapoints took 8.767441s
2021-02-09 22:28:50 DEBUG (SyncWorker_45) [homeassistant.components.history] Extracted 4017 states in 11.901393s
2021-02-09 22:28:51 DEBUG (Recorder) [homeassistant.components.recorder] Sending keepalive
2021-02-09 22:28:52 DEBUG (SyncWorker_10) [homeassistant.components.recorder.util] querying 16 rows took 10.193875s
2021-02-09 22:28:52 DEBUG (SyncWorker_10) [homeassistant.components.history] getting 16 first datapoints took 10.197701s
2021-02-09 22:28:52 DEBUG (SyncWorker_10) [homeassistant.components.history] Extracted 7206 states in 14.002799s
2021-02-09 22:28:53 DEBUG (SyncWorker_37) [homeassistant.components.recorder.util] querying 7199 rows took 0.120140s
2021-02-09 22:28:53 DEBUG (SyncWorker_37) [homeassistant.components.history] get_significant_states took 0.120322s
2021-02-09 22:28:53 DEBUG (SyncWorker_37) [homeassistant.components.recorder.util] querying 16 rows took 0.032555s
2021-02-09 22:28:53 DEBUG (SyncWorker_37) [homeassistant.components.history] getting 16 first datapoints took 0.036247s
2021-02-09 22:28:53 DEBUG (SyncWorker_37) [homeassistant.components.history] Extracted 7205 states in 0.175908s
2021-02-09 22:28:54 DEBUG (SyncWorker_17) [homeassistant.components.recorder.util] querying 15 rows took 11.298667s
2021-02-09 22:28:54 DEBUG (SyncWorker_17) [homeassistant.components.history] getting 15 first datapoints took 11.301585s
2021-02-09 22:28:54 DEBUG (SyncWorker_17) [homeassistant.components.history] Extracted 5975 states in 15.177097s
2021-02-09 22:28:56 DEBUG (SyncWorker_36) [homeassistant.components.recorder.util] querying 18 rows took 12.423784s
2021-02-09 22:28:56 DEBUG (SyncWorker_36) [homeassistant.components.history] getting 18 first datapoints took 12.426979s
2021-02-09 22:28:56 DEBUG (SyncWorker_36) [homeassistant.components.history] Extracted 8807 states in 17.760508s
This is one example, but some other things are worse…I’m hoping there is a way to improve this.
