I am running HA 2025.12.5 on bare metal… My goal is to shutdown my backup unraid system via an automation when the power load drops to a set point for 4 minutes. This all worked when running the Unraid-API-RE container on Unraid prior to upgrading server to 7.2.x. The container was designed for 6.x.x and just became broken.
I had a switch defined in HA that would bring up the machine with WOL (still works) and then would take it down with an Unraid-API-RE service call (quit working). So, I decided to do the shutdown via a command line in the switch config. The command line works perfectly via the HA cli, but will not work when the switch is clicked or an automation tries to use it.
I have added a command_lines.yaml to my config directory and done the require include in the configuration.yaml file. The command is being found as indicated by the error logs.
Error message:
Logger: homeassistant.components.shell_command
Source: /usr/src/homeassistant/homeassistant/components/shell_command/__init__.py:129
integration: Shell Command (documentation, issues)
First occurred: 12:47:41 PM (1 occurrence)
Last logged: 12:47:41 PM
Error running command: `ssh -v -i /config/.ssh/id_rsa_unraid [email protected] 'shutdown -h now'`, return code: 255
NoneType: None
This exact command from the cli in HA works perfectly and returns exit code 0 as it should:
shell_commands.yaml entry"
turn_off_backup_server: "ssh -v -i /config/.ssh/id_rsa_unraid [email protected] 'shutdown -h now'"
I do have turn_off_backup_server appearing in developer tools as shell_command.turn_off_backup_server
switch.yaml entry for device:
- platform: wake_on_lan
mac: "BC:5F:F4:xx.xx.xx"
host: 192.168.1.xxx
broadcast_address: 192.168.1.255
turn_off:
service: shell_command.turn_off_backup_server
What am I doing wrong, gonna wear my HA machine out rebooting for each test change a this point. I have tried many iterations of the shutdown command and added -v so that when tested from the cli I could see the entire process and it all looks great. I have tried it with and without sudo and the ’ ’ around the command and no difference. The sudo should not be required by this user.
I seem to get this error on unraid.
Jan 16 13:12:38 Backup sshd-session[34134]: Connection closed by 192.168.1.6 port 53348 [preauth]
Jan 16 13:12:38 Backup sshd[1781]: srclimit_penalise: ipv4: new 192.168.1.6/32 deferred penalty of 1 seconds for penalty: connections without attempting authentication
Thanks Matt
