Trying to setup Zigbee2mqtt ona a HA Green with SkyConnect
Hello everyone,
newbie here. I’ve recently got the Home Assistant Green with the Home Assistant SkyConnect and wanted to install Zigbee2MQTT. First I followed the official guide from the Zigbee2MQTT website and then when it wasn’t working I checked this YT video https://youtu.be/nNLgCUFRNsk?si=8xwcsP7uClrK_QTT However, I am still running into issues. Basically when checking the log the app gets stuck trying to run the Zigbee-herdsmen and then fails
Zigbee2MQTT:error 2024-02-22 22:33:55: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-22 22:33:55: Failed to start zigbee
I tried different settings, but also noticed that the SkyConnect is not really a recommended device and is listed under the Experimental category. However, from reading the description there should not be any major issue unless I would want to use it with Threads.
This is my setting. I am using the HA MQTT addon and according to the official guide when the addon is used the mqtt field should remain empty.
Is anyone here using the SkyConnect with Zigbee2MQTT and can help?
Ok nevermind, I worte the port with a lowercase “usb” instead of ttyUSB0. Now it works
