@Tom_I - I’m very new to this so pretty much nothing in the documents makes sense. I assumed that the response_variable: generated_content on the first line of the snippet declared the variable, which should have been outside the if statement scope.
I wasn’t trying to declare a second variable with the same name as the former within the IF block scope; I was trying to give it a value if the google_generative_ai action failed.
Thanks Tom_I. With your help, I am getting closer. I now have:
- metadata: {}
prompt: >-
Check images 1-3 and briefly describe any movement. If a person or car
is moving, give details. If no motion, reply "No Obvious Motion
Detected". Keep it short for a phone notification.
image_filename:
- ./www/snapshots/{{ camera_name }}_snapshot1.jpg
- ./www/snapshots/{{ camera_name }}_snapshot2.jpg
- ./www/snapshots/{{ camera_name }}_snapshot3.jpg
continue_on_error: true
action: google_generative_ai_conversation.generate_content
- variables:
filtered_content: >-
{{ 'Google AI Error' if generated_content is none else
generated_content.text }}
- if:
- condition: template
value_template: "{{ 'no obvious motion detected' in filtered_content | lower}}"
then:
- stop: ""
else:
- action: shell_command.fixup_jpeg
image_file: ./www/snapshots/{{ camera_name }}_snapshot3.jpg
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- metadata: {}
title: "{{ camera_name }} Motion Detected"
message: "{{filtered_content}}"
images:
- /config/www/snapshots/{{ camera_name }}_snapshot3.jpg
action: notify.family_sms
mode: single
However, occasionally I’m getting the following error:
Template variable error: 'generated_content' is undefined when rendering '{{ 'Google AI Error' if generated_content is none else generated_content.text }}'
I’m assuming the error occurs when the google_generative_ai_conversation.generate_content call fails. I thought that would have been caught by the if generated_content is none clause. That is what I was hoping was the test for “undefined”.
Any additional words of wisdom?
Late addition - I saw a reference to == empty, so I’m trying that as a test for undefined now.
I am setting filtered_content to an error message string when the response variable, generated_content, does not exist (i.e. the google conversation call fails). If the response variable does exist, then I am setting filtered_content to the text string contained within generated_content.test. generated_content.text should only be used after generated_content has been confirmed as being set.
The problem I’m having is the correct test to determine if the response variable, generated_content, exists. Multiple examples on the web show is none, is defined, == empty. Which is the correct test?
My earlier post (deleted now) was incorrect; I failed to recognize that you have two separate variables, generated_content and filtered_content.
The problem definitely looks to be that generated_content is sometimes not defined, so the is none test throws an error. Presumably you are seeing both the possibility of the variable being undefined and being none (which are two different things). I’d use this:
- variables:
{{ 'Google AI Error' if generated_content|default(none) is none else
Dominic - thanks. Part of the problem is my lack of understanding of the terminology and therefor inability to Google for solutions. To me, the line response_variable: generated_content defines the variable.
If google_generative_ai_conversation.generate_content fails, then generated_content is left uninitialized, and therefore attempting to access generated_content.text results in a failure.
So my quandary is how to test for generated_content being uninitialized after a failure of the calling function. I cannot find a definitive solution in the HomeAssistant documentation, and I’ve now seen four different “tests” leaving me totally confused.
I realize there is the additional possible error in that generative AI conversation could “succeed” and still return an uninitialized text string. I’m going to ignore that possibility for now and blissfully assume it would just be set to an empty string.
Variable nuances are an unfortunately vexing part of scripting and response variables, in particular, are a bit of a black box. What you say there is a reasonable expectation, but I don’t think it’s guaranteed, especially if the response variable is coming from something other than a script. Just going by the error message that you’re seeing, you’re clearly hitting a situation where generated_content is not defined.
I’d expect you can replace empty with dhudvbxcpycg and find no difference in behavior.
You’re checking equality of two undefined variables. empty is not some special object; it’s simply a variable that hasn’t been defined. And any two undefined variables will equal each other. {{ gecjrsv == ptefjtv }} will render true because they are both undefined variables. Why not explicitly check if generated_content is undefined instead of checking if it is equal to some random undefined variable?
You marked the approach with empty as a solution but, if that works, it’s at best by accident and should not be used by others.
If you search the web for information about Jinja–or, if you really want to tempt death, use an LLM to write the code for you–you can often find “solutions” that work for other platforms that have extended Jinja in ways that are not applicable to Home Assistant. The only authoritative documentation on Jinja for Home Assistant is the Template Designer Documentation and the Home Assistant Templating documentation. Neither of those documents discusses an empty function, filter, or other thing.
So there is no such thing as empty. That’s just an undefined variable, same as hogwarts. You can prove this to yourself by trying the following in the Template Editor:
{{ empty }}
And if you feel like running a second experiment,
{% set empty = 'This is a string assigned to the variable named empty.' %}
{{ empty }}
Incidentally, it looks like (using the Template Editor) if you try to compare two undefined variables with ==, you get true (rather than an error). So at best what you’re doing incidentally does what is undefined would do, and that’s only because you haven’t defined empty as a variable.
