Trying to understand xiaomi config
Hi All,
Relatively new user to home assistant. Managed to wire up a newly purchased xiaomi starter kit, couple of yeelights and Wake On Lan for my computer.
I don’t have a particular problem but don’t understand a bit of the config in Hi All,
I don’t have a particular problem but don’t understand a bit of the config page in Hi All,
I don’t have a particular problem but don’t understand a bit of the example on the motion section https://home-assistant.io/components/binary_sensor.xiaomi_aqara/#motion
The action for turning on the light when dark states
    - service: light.turn_on
      entity_id: light.gateway_light_34ce00xxxx11
        brightness: 5
    - service: automation.turn_on
        entity_id: automation.MOTION_OFF
I understand the first service but not the second. Re-reading it now I’m guessing it’s making a particular automation active (i.e. allowing it to activate) BUT if that’s true I have 2 issues:
  1. I can’t see how automation.MOTION_OFF is assigned to the next automation ‘- alias: If there no motion for 5 minutes turn off the gateway light’ from what I can tell the entity id will become a slug for the alias so something like ‘automation.if_there_no_…’
  2. Is it even necessary? the trigger is ‘from on to off for 5 minutes’. I am guessing that it’s trying to only turn it off if the previous automation turned it on. (i.e. so if I turn on the light when it’s bright and trigger the automation sensor, I won’t turn it off)
I’d like to know if my reading is correct, and if it is a means to protect the automation from happening arbitrarily, is that the best way?
Thanks for the help!
Hello @ewanrw,
same here, and now with hassio 0.106.4 i have a warning : “Unable to find referenced entities automation.motion_off”
Have you try without
        entity_id: automation.motion_off
thanks
I’m getting “Unable to find referenced entities” for no reason as well… I can’t call a script from an automation.
