Trying to use deep sleep with advanced features on an esp32-c3
Hi, I am not sure where to start this, it could be related to several things.
I am trying to setup an ESP32-c3 with a wake up from two different pins.
The esp32_ext1_wakeup feature is not too well documented, so first, this could be something to improve in the doc.
After some research, I finally found how to write the code without getting errors at the yaml validation.
Alas, at the compilation level I got errors, Okay… some more research, then I find a post where it says, that, finally it would not work on the C3 devices ???
Here is the link to the github post:
The fatal answer right at the bottom of the post.
Hmm, Where are the limitations listed in the doc ?
And now the big questions:
  • Is there a work around (apart from adding some more circuitry outside).
  • Is there a list of ESP32 devices that really support this feature in ESPHome ?
  • Will there be a change at some point for the c3, or should I request a change ?
From the Expressif doc, I do not see that the limitation is the chip itself (I may be wrong), so I assume this is rather in the ESPHome implementation of ESP32-c3.
Any comment or ideas are welcome.
Sounds like a hardware limitation. Personally I’d just get another board.
Not that I’m aware of. I think part of the issue here is that the new esp32 variants (C3, S2, S3 etc) have added more variety /complexity to the hardware landscape, and the ESPHome docs have struggled a bit to keep up.
Well ssieb who closed that issue knows the project very well. Sounds like it needs a docs update to explain it’s not possible plus some config validation to flag it to users if they try. If you want to contribute to the above I would ping ssieb on Discord, making reference to this thread, and ask if you can be of any help (including confirming if it’s a hardware limitation and raising any change requests wanted).
Thanks a lot for this detailed answer. I already tried to find out if other types would compile without throwing insults at me. Looks like esp32-s3 is a good candidate. But I have already a few c3 boards and if I can avoid buying again, all the better.
As I looked at the Arduino side of things(documentation), I was under the impression that this advanced option for deep sleep is available with c3 chips.
In any case, I will do as you suggest and contact ssieb.
S3 is probably fine now. But you will have no problems with an original esp32.
If your project is battery powered you need to be very careful in selecting a board for optimal low power - the circuitry needs to be designed for it.
Maybe this thread is of some help in selecting a board.
Thanks for the additional tips. I sent a direct message to @ssieb on the discord server, but he did not seem to reply. For the time being, I will try to stick to my c3 boards and I will just split the two inputs to one GPIO pin with schottky diodes and try to workaround my problem that way. Not ideal, but I prefer that to buying, again, some new hardware that I do not know yet.
I will update this thread later when I have something relevant.
Just send it on the ESPHome Discord “General Support” thread. He’ll quite likely reply there…
Something interesting, but maybe it is already known: I was programming a board, ESP32-c3 super mini. First, I did not use my antistatic mat, and I probably fried one that way. :face_with_open_eyes_and_hand_over_mouth:
Now the second was showing inconsistent results regarding the wifi connection. This was until I noticed that it was bad whenever I put it on the breadboard. Just dangling it on a USB cable, everything was fine.
Apparently, the breadboard has a big dampening effect on the signal. So I bent the pins 90 degrees on one side and installed the circuit vertically. Now everything is OK, I can experiment some programming.
Yes, lots of similar reports on the forum. There are “bad batches” floating around too.
I looked at my c3 boards, and yes, they look like the ones with the small gap, but I suspect this is more complicated than that. If they do not lay flat on a breadboard, they seem to work ok.
Anyway, I ordered s3 boards now and also c6, as I wanted to look at the zigbee
option and realized that it needs again another type. :face_with_raised_eyebrow:
Btw, I think this tread can be closed. The solution is probably to use an S3 board.
Thanks for the help.
