Trying to view template result on card
I have a system that triggers watering based moisture level. The moisture detection part is powered by a rechargeable battery that is charge by solar via TP4056. On that module there is a LED that indicates when it is charging and a different LED to indicate when fully charged. I have wired both LEDs to 2 IO pins of esp8266 and I currently view the status but not in a way that I want. This is the current view:
Capture
Instead, I would like to see only one line with a status of either ‘Charging’, ‘Not charging’ or ‘Fully charged’
In the Developer tools > Templates I have this code and it works:
{% if is_state("binary_sensor.04_charging", "On") %}
Charging
{% elif is_state("binary_sensor.04_full_charge", "On") %}
Fully Charged
{% else %}
Not Charging
{% endif %}
How do I get the result of this template to show on a card?
With a Mushroom template you can do it (here is my logic for one of my solar batteries)
{% if states('sensor.solax_battery_power_charge') | int(0) == 0 %}
    Idle
{% elif states('sensor.solax_battery_power_charge') | int(0) < 0 %}
  {{states('sensor.solar_remaining_battery_hours')}}
{% elif states('sensor.solax_battery_power_charge') | int(0) > 0 %}
  {{states('sensor.solar_remaining_charge_time')}}
{% endif %}
@Neil_Brownlee
Thanks for the quick response. I am looking into Mushroom cards, it can take me some time to understand well as what I need to display is based on a template resulting from the state of two entities.
EDIT: It actually took me 10 minutes to understand and working well. :+1:
