TS0044 Switch: Automation Missing
I recently got the TS0044 switch for my home.
The addition worked without a problem and in Zigbee2Mqtt I can see the device has all four endoints correctly added.
Now I wanted to assign an automation for each of the switches, however when I select the device, I only get trigger options:
-“2_single”
-“battery”
I would expect there should be “1_single” - “4_single” (and probably some double as well, but they are not important now).
Since they device has all endoints visible in Z2M, it seems to me that the problem is within HA Automation.
Can somebody help me to solve this issue?
Press those missing buttons one by one while looking at the log on the device page.
Once you confirm they are shown in the logs, go to the automation page & you should be able to see them now
