TS0222 by _TZ3000_7kscdesh Illuminance Zigbee sensor
I have successfully added a TS0222 by _TZ3000_7kscdesh to my HA via ZIGBEE and works well. The only issue is that HA reports the maximum illuminance as 1000lux but if I interrogate the values via “manage my zigbee device’ and read the value 'IlluminanceMeasurement (Endpoint id: 1, Id: 0x0400, Type: in)” & “Attributes of the selected cluster measured_value (id: 0x0000)” , the lux is can be higher than 1000. This means HA is limiting the value returned.
How can I change the upper MAX / limit for this device?
Solved!
Developer tools > States > Set State > _TZ3000_7kscdesh TS0222 > State = 1000. Changed this to 40000.
Not fixed. Still have the same issue.
The devices logs show:
“state”: {
“class_name”: “Illuminance”,
“available”: true,
“state”: 1000
