duncang92
(Duncang92)
1
I received this humidity/temp sensor for Christmas
It is recognised and added in ZHA although there is no humidity/temp infor etc.
I found this adding support … [External Converter]: TS0601 from _TZE284_cwyqwqbf · Issue #30128 · Koenkk/zigbee2mqtt · GitHub
Says “This device is now supported in version 2.7.1” I assume this to be the ZHA version
How do I know if I have this version or not? I see where to check core software release in the GUI but cannot find ZHA info.
Thanks, Duncan
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
2
Quirks ZHA Device Handlers & How-to & Older How-to
No, that is Zigbee2MQTT. It’s a different Zigbee integration.
duncang92
(Duncang92)
4
I editied the configuration.yaml file to add
zha:
enable_quirks: true
custom_quirks_path: /config/custom_zha_quirks
created custom_zha_quirks folder and created a file called TS0601_TZE284_cwyqwqbf.py with tthe contents specified at [External Converter]: TS0601 from _TZE284_cwyqwqbf · Issue #30128 · Koenkk/zigbee2mqtt · GitHub
I see no change after restarting the system, it still doesn’t show me any entities other than firmware.
I am definitely not an expert here and trying to learn.
Thanks,
Duncan
Sir_Goodenough
5
You can’t add a Zigbee2MQTT external converter to a ZHA network.
You need to find or make a ZHA Quirk and put it there.
Hedda
(Hedda)
6
Zigbee2MQTT and its zigbee-herdsman converters have nothibg to do with ZHA (or zigpy) and its ZHA Device Handlers (which are also known as zha-quirks). Read → Zigbee Guide: How-to add/setup local custom ZHA Device Handlers (also known as ”quirks”) in the ZHA integration
