TS0601_TZE204_aoclfnxz Thermostat for underfloor heating, properties are not visible
Hello everyone, I have encountered a problem that unfortunately I cannot find a solution to.
Previously, all ZigBee devices I purchased connected to my HA without problems, but after purchasing this thermostat, I first encountered the fact that after connection, there are only two parameters LQI & RSSI.
Having searched for information, I came across the fact that this problem is widespread due to the use of non-standard protocol functions, and that there seem to be methods for solving this problem. But everywhere some separate pieces, python scripts, pieces of config are discussed and I could not understand where to start solving this problem.
If someone would be kind enough to tell me step by step what steps need to be taken, I would be grateful, since at the moment I don’t even know where to start.
I sorry, a new user can only send one photo, if you need others I will add via GoogleDrive
Identification at HomeAsistant:
TS0601
_TZE204_aoclfnxz
Zigbee info
IEEE: a4:c1:38:a5:e5:9d:21:b4
Nwk: 0x5122
Device Type: Router
LQI: 132
RSSI: none
Connected: 2025-06-21T10:20:51
Powered: Mains
Diags
Connection logs:
