TS0601 Zigbee radiator thermostat not recognized as thermostat
Hello, I have bought the following Hama radiator thermostat in the past as starter set with 2 thermostats. I have successfully integrated the 2 thermostats ("_TZE200_yw7cahqs TS0601") in Home Assistant using the SkyConnect Zigbee Adapter. Later I have bought 6 additional Hama radiator thermostats. The problem I now have is that those thermostats ("_TZE200_h4cgnbzg TS0601") are not recognized as thermostats in HA.
How can I get them integrated as thermostats in Home Assistant?
Incorrect recognized thermostat
  "home_assistant": {
    "installation_type": "Home Assistant Container",
    "version": "2022.12.8",
    "dev": false,
    "hassio": false,
    "virtualenv": false,
    "python_version": "3.10.7",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/Berlin",
    "os_name": "Linux",
    "os_version": "5.15.76-v8",
    "run_as_root": true
  "custom_components": {},
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "config_flow": true,
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "requirements": [
      "bellows==0.34.5",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.89",
      "zigpy-deconz==0.19.2",
      "zigpy==0.52.3",
      "zigpy-xbee==0.16.2",
      "zigpy-zigate==0.10.3",
      "zigpy-znp==0.9.2"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
    "dependencies": [
      "file_upload"
    "after_dependencies": [
      "onboarding",
      "usb",
      "zeroconf"
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 53480,
    "manufacturer": "_TZE200_h4cgnbzg",
    "model": "TS0601",
    "name": "_TZE200_h4cgnbzg TS0601",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "manufacturer_code": 4417,
    "power_source": "Battery or Unknown",
    "lqi": 72,
    "rssi": -82,
    "last_seen": "2023-01-01T19:30:53",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": 260,
          "device_type": "0x0051",
          "in_clusters": [
            "0x0000",
            "0x0004",
            "0x0005",
            "0xef00"
          "out_clusters": [
            "0x000a",
            "0x0019"
    "active_coordinator": false,
    "entities": [],
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "SMART_PLUG"
    "user_given_name": null,
    "device_reg_id": "5e99fb1896deba1de4f038ae7042e4f9",
    "area_id": "kinderzimmer_og",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "SMART_PLUG",
          "id": 81
        "profile_id": 260,
        "in_clusters": {
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
            "unsupported_attributes": {}
          "0x0005": {
            "endpoint_attribute": "scenes",
            "attributes": {},
          "0xef00": {
            "endpoint_attribute": null,
            "attributes": {},
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "_TZE200_h4cgnbzg"
              "0x0005": {
                "attribute_name": "model",
                "value": "TS0601"
        "out_clusters": {
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
          "0x000a": {
            "endpoint_attribute": "time",
            "attributes": {},
Correct recognized thermostat:
  "home_assistant": {
    "dev": false,
    "hassio": false,
    "docker": true,
    "arch": "aarch64",
    "os_name": "Linux",
    "run_as_root": true
    "domain": "zha",
    "requirements": [
      "bellows==0.34.5",
      "pyserial==3.5",
      "zigpy==0.52.3",
      "zigpy-znp==0.9.2"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
        "vid": "1A86",
        "pid": "55D4",
        "known_devices": [
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1CF1",
        "pid": "0030",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "known_devices": [
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "zeroconf": [
        "name": "tube*"
        "name": "*zigate*"
        "name": "*zigstar*"
    "dependencies": [
      "file_upload"
      "onboarding",
      "usb",
      "zeroconf"
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "is_built_in": true
  "data": {
    "nwk": 39633,
    "manufacturer": "_TZE200_yw7cahqs",
    "model": "TS0601",
    "name": "_TZE200_yw7cahqs TS0601",
    "quirk_applied": true,
    "quirk_class": "zhaquirks.tuya.ts0601_trv_sas.Thermostat_TZE200_c88teujp",
    "manufacturer_code": 4098,
    "lqi": 188,
    "rssi": -53,
    "last_seen": "2023-01-01T21:40:17",
    "available": true,
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": 260,
          "device_type": "0x0301",
          "in_clusters": [
            "0x0000",
            "0x0001",
            "0x0004",
            "0x0005",
            "0x0201",
            "0xef00"
          "out_clusters": [
            "0x000a",
            "0x0019"
    "entities": [
        "entity_id": "sensor.tze200_yw7cahqs_ts0601_battery",
        "entity_id": "sensor.tze200_yw7cahqs_ts0601_hvac_action",
        "entity_id": "climate.tze200_yw7cahqs_ts0601_thermostat",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "THERMOSTAT"
    "device_reg_id": "68c8a5f191e29d3170895434d16f8697",
    "area_id": "sonstiges",
      "1": {
        "device_type": {
          "name": "THERMOSTAT",
          "id": 769
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "attributes": {
              "0x0004": {
                "value": "_TZE200_yw7cahqs"
              "0x0005": {
                "value": "TS0601"
              "0x0013": {
                "attribute_name": "alarm_mask"
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {
              "0x0021": {
                "attribute_name": "battery_percentage_remaining",
                "value": 200
          "0x0004": {
            "attributes": {
              "0x0000": {
                "attribute_name": "name_support",
                "value": 0
              "0xfffd": {
                "attribute_name": "cluster_revision",
                "value": 2
          "0x0005": {
            "attributes": {},
          "0x0201": {
            "endpoint_attribute": "thermostat",
            "attributes": {
              "0x0000": {
                "attribute_name": "local_temperature",
                "value": 2130
              "0x0012": {
                "attribute_name": "occupied_heating_setpoint",
                "value": 1700
              "0x0015": {
                "attribute_name": "min_heat_setpoint_limit",
                "value": 500
              "0x0016": {
                "attribute_name": "max_heat_setpoint_limit",
                "value": 3000
              "0x001b": {
                "attribute_name": "ctrl_sequence_of_oper",
                "value": 2
              "0x001c": {
                "attribute_name": "system_mode",
                "value": 0
              "0x001e": {
                "attribute_name": "running_mode",
                "value": 0
          "0xef00": {
            "endpoint_attribute": "tuya_manufacturer",
            "attributes": {
              "0x0165": {
                "attribute_name": "state",
                "value": 0
              "0x0267": {
                "attribute_name": "heating_setpoint",
                "value": 170
              "0x0266": {
                "value": 213
              "0x0569": {
                "attribute_name": "battery_state",
                "value": 0
              "0x016c": {
                "attribute_name": "schedule_enabled",
                "value": 0
        "out_clusters": {
          "0x000a": {
            "attributes": {},
          "0x0019": {
            "attributes": {},
