Tstat override
Im using a Boolean toggle as an override switch in the automation below… Problem is if I have the Boolean switch on ( override mode) and the automation goes past the trigger point before I turn the switch off it won’t fire…
ideas??
alias: Above 85
description:""
- platform: numeric_state
entity_id: sensor.exterior_temp_humidity_temperature
above: 85
condition:
- condition: state
entity_id: input_boolean.tstat_overrider
state: "off"
- service: climate.set_temperature
temperature: 68
hvac_mode: cool
device_id: 65cdd22f1fd274760ede0b4d19d731be
mode: single
BTW i have 3 automations for different outside temp and use the boolean across all of them
ideas
Dan
