I did post about this on the integration repository but no reply yet and I suspect it may be a HAss problem however, I’m not sure.
For some reason, no clue why, as the integration has been working fine for over a year and there wasn’t even any updates or reboots, it just stopped working this morning.
I see this message in the logs:
Logger: homeassistant.config_entries
Source: config_entries.py:4040
First occurred: 00:07:18 (2 occurrences)
Last logged: 00:12:38
Error occurred loading flow for integration ttlock: RuntimeError importing custom_components.ttlock.config_flow: unable to infer type for attribute "id"
Obviously tried a restart, then reboot but no change.
So I tried to delete the OAuth stuff, which failed as it was “in use”.
I then deleted the integration totally, checked the files and it was gone. re-downloaded it. Reinstalled it. Several times with restarts/reboots to try to get it to stop giving me the very annoying invalid handler error but to no avail.
I am totally stuck, I have no idea why I’m getting that error when the integration has been completely removed and reinstalled, it makes no sense to me.
