I use tts.home_assistant_cloud and I would like to know how to make the announcement volume optional and also how to disable the “ding” sound at the beginning of the announcement?
Thank you
Thank you
Simply don’t include it in your action. TTS will use the last value the media player volume was set to.
Cloud TTS does not make a “ding” sound at the beginning of an announcement. That is coming from whatever you are using as the media player.
Thank you for your reply.
Sorry, I speak English and the translation is approximate.
My wish is to make the announcement volume optional, like this:
service: tts.speak
media_player_entity_id: media_player.cuisine
message: "Votre message"
cache: false
options:
volume_level: 0.5
entity_id: tts.home_assistant_cloud
Regarding the “ding” sound, I only use Google Home devices.
That is where the “ding” is coming from. Nothing to do with Home Assistant.
You have to adjust the volume in a separate action:
actions:
- action: media_player.volume_set
volume_level: 0.5
- action: tts.speak
cache: false
I understand, yet I come from Jeedom and the TTS Cast plugin allows you to remove the “ding”.
https://titidom-rc.github.io/Documentation/fr_FR/TTSCast/index#:~:text=ding%20%3A%20Si%20cette%20option%20est%20mise%20à%20false%20%3A%20Permet%20d’enlever%20le%20“ding”%20présent%20au%20début%20de%20l’annonce%20sur%20un%20Google%20Home%20(Ex%3A%20"ding"%3A%20false)
You need to edit voice device yaml file and add button.
This button will be used in ding action trigger if statement
If button on no ding
If button off ding
There is similar button used for mute.
You can use that as reference
Thank you, can you help me with this procedure?
Is this for esp voice device?
are you controlling setting in esphome device builder?
if not my suggestion does not apply. If so, what device are you using?
