Turn off a/c outside temp is xx
Looking to setup an automation to turn off my air-conditioning (ecobee thermostat) when the outside temperature is less than 77 degrees.
I can find weather temperature but not sure how to set the less than 77 degrees part
Use a Numeric State Trigger with below: 77 to trigger the automation when the sensor, monitoring exterior temperature, decreases below 77.
