For testing on dev, I’ve spun up another instance of home assistant on my RPI3, my master instance runs on RPI4
Is there a way, without changing the config files (as I need to be able to merge changes from dev to master) to be able to turn off all automations on the dev instance?
This does work, but was hoping for a more automated way, as this will require me to run it with each restart to the dev instance - which may be many times
Although i wouldn’t be able to do this as a automation on start up, as when I merge to master for the main instance, it would go over also
