Turn off iMac display running HAOS
Hi all! Starting fresh with Home Assistant, (quickly) moving away from the big “A”. I have an older iMac that I’ve erased and loaded Home Assistant OS onto. My question is: is there any way to have the Home Assistant OS turn the iMac display off once it has loaded itself? Right now it’s sitting there with the usual command line up, but I’d like it to put the display to sleep. Seems like my server set-up is slightly out of the norm versus a Green or PC with an attached monitor. Thank you!
It has been requested a few times, but I do not think it has been accepted by the devs yet.
It is not only on Macs the issue present itself. PCs and Raspberries have the same issue.
