Thanks for reply. Apparently, SIM800l only works with 2G networks, which most providers (such as at&t etc) have phased out…
Are you still able to get your SIM800l module working (with 1nce) in the US ??
Hi together,
is this function still being worked on?
I would also like to use the possibility to disable wifi via CAN bus.
What I tested with CAN is to do the WiFi.mode(WIFI_OFF)
successfully, but Wifi immediatly switches back on.
It also seems that https://github.com/esphome/esphome/pull/1249 is still active?
