Turn_on cannot be called without entity_id
I’d like to run this script inside an automation.
luci_letto_sunrise:
  alias: Sunrise Luci Letto
  sequence:
    - service: light.turn_on
      entity_id: group.luci_camera_letto
        transition: 1
        brightness_pct: 1
        rgb_color: [0,255,0]
    - delay: 00:00:30
        transition: 9
        brightness_pct: 10
    - delay: 00:00:10
        transition: 10
        brightness_pct: 20
I call it with:
    - service: script.turn_on
        entity_id: script.luci_letto_sunrise
From the log I see that the automation is executed, but I get:
ERROR (MainThread) [homeassistant.components] homeassistant/turn_on cannot be called without entity_id
I can’t find where the error is!
Thanks.
I don’t think that error is related to the script and automation you’ve posted.
Grep your configuration files for
service: homeassistant.turn_on
And find the one that doesn’t have an entity_id attached.
Call a script like:
  - service: script.luci_letto_sunrise
or without the data like this
  entity_id: script.ios_update
Removing the “data” line made the work!
Than you! :grinning:
