Goodnight. I wanted to create an automation for my led tape to turn on when the cell phone battery was below 20%. I’m not able to turn it off when the battery is above 20%. Someone can help me?
alias: aa
description: ''
- platform: numeric_state
entity_id: sensor.iphone_11_tr_battery_level
above: '0'
below: '20'
condition: []
- service: light.turn_on
entity_id: light.fita_led
mode: single
finity
December 1, 2021, 12:54am
2
below: '20'
above: '20'
- service: light.turn_{{ 'on' if states('sensor.iphone_11_tr_battery_level') | float < 20.0 else 'off' }}
mode: single
Stick an id of ‘on’ and ‘off’ in the triggers. Then in service you can just use
light.turn_{{ trigger.id }}
without the need for the if stuff.
finity
December 1, 2021, 12:58am
4
Yeah, I keep forgetting about the new trigger id stuff. That would be cleaner but either way will work.
I personally use choose blocks with trigger id’s. Waaaay more verbose but still easy peazy with the UI and I suspect more future-proof/less likely to break later.
in this case, could you tell me how it would look?
Hellis81
(Hellis81)
December 1, 2021, 11:22am
8
I would make it “above: 20 and below: 100”, and “above: 0 and below: 20”.
The way it is now it will send commands to the LED strip every time the battery level changes.
finity
December 1, 2021, 4:09pm
9
nope.
it will only trigger the automation one time as the battery level drops below 20 and then only once when it goes back above 20 again.
the numeric state trigger only becomes true when it crosses the threshold . not continuously when it is below that threshold.
Something is wrong with the action… :s
finity
December 2, 2021, 7:41pm
11
really?
I’m pretty sure it’s ok but just in case try this instead:
- service: >
also you can check the logs or automation trace to try to see why the automation is failing.
as a matter of fact I just created a test automation and tested it and verified it worked:
- alias: test battery automation
entity_id: input_number.test_input_number
below: '20'
above: '20'
- service: light.turn_{{ 'on' if states('input_number.test_input_number') | float < 20.0 else 'off' }}
entity_id: light.comp_corner_lamp_1df9
mode: single
if I set the input number to 19 the light goes on and if I set it to 21 the light goes off.
So it has to be some other reason that the action syntax being wrong.
Good afternoon. just one more question. if I want to put more devices with the same rule, in the same automation, how is it?
finity
December 10, 2021, 2:54pm
14
asuming you want to turn on and off the same light:
entity_id:
- sensor.iphone_11_tr_battery_level
- sensor.iphone_some_other_battery_level
- sensor.iphone_and_another_battery_level
below: '20'
entity_id:
above: '20'
- service: >
light.turn_{{ 'on' if trigger.to_state.state | float < 20.0 else 'off' }}
mode: single
hi… The light does not turn off when the battery goes above 20%. Do you know what it might be?
finity
December 18, 2021, 11:25pm
16
Not really.
Have you looked at the automation trace to see why it isn’t working?
