im trying to make simple altomation but i struggle doing it
i have a termoprobe which reports temperature numbers like 22.10 and simple shelly1 switch
This is the code i manage to piece together ^^
- id: '123123123123'
alias: turn switch on base on temperature
description: "turning switch on if temperature is below 30 and turning it off if temperature is over 30"
- platform: numeric_state
entity_id: sensor.1pm_temperature_probe_0
- service: >
{% if states('sensor.1pm_temperature_probe_0') | int <= 26 %}
switch.turn_on
{% elif states('sensor.1pm_temperature_probe_0') | int >= 30 %}
switch.turn_off
{% endif %}
entity_id: switch.shelly1
All of my reqdings and commands go trough mqtt brocker
Numeric state triggers require either an above or below key (or both)… In this case you would be better off using two Numeric state triggers with ids that can be used to determine the service type used.
Also, your action was missing the target key.
description: "turning switch on if temperature is below 26 and turning it off if temperature is over 30"
above: 29.9
below: 26.1
- service: switch.turn_{{ trigger.id }}
I do not know is it HA related or i need to make changes in the code but:
if this code run, and turn on the the switch when temperature is below 26, and i manually turn off the switch, it does not turn on again when the new reading of 24( for example) comes again. So now the temperature is under 26 but the switch does not switch on till i make temperature go over 26 and go back down below 26.
Is it there a way for automation to check every cycle and make it turn on the switch again when readings are below 24 even if i turn it off before last cycle reading?
That is the expected behavior. A Numeric state trigger only fires when the numeric value of an entity’s state crosses a given threshold. Once fired, the trigger will not fire again until it is reset by crosses the threshold in the opposite direction.
If you need to, it is much more efficient to add one or more fallback triggers with the same id. than to use continuous polling.
above: 29.9
below: 26.1
above: 31
below: 24
It is possible to check the value of the sensor on a regular polling cycle using the Time Patter trigger. This is not the recommended method to use because it is inefficient. To use that method you would need to redesign the automation significantly.
Good suggestion but it does not fit my case
i cannot set a range between 2 points of temperature
also i used the code from Generic Thermostat - Home Assistant and it did not turn on my device after i set comf.temp. to be 30.
Make sure you address the use case of the thermo probe going offline. As otherwise the heat may remain on for a long time when that sensor fails or the comms to the sensor goes down.
