Turn on switch when there is no movement- automation help
Hi
I’m trying to configure my first automation. When there will be no movement for 10 minutes turn on switch accessory. Here is my configuration, can you help me ? Please
I get this error in log:
17-03-26 01:10:11 ERROR (MainThread) [homeassistant.loader] Unable to find component automation.rpi_gpio
17-03-26 01:10:11 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: platform rpi_gpio does not exist for automation for dictionary value @ data[‘trigger’][0][‘platform’]. Got None. (See /var/opt/homeassistant/configuration.yaml, line 24). Please check the docs at https://home-assistant.io/components/automation/
automation:
  • alias: Turn on switch 10 minutes after last movement
    platform: rpi_gpio
    entity_id: binary_sensor.motionsensor
    to: ‘off’
    for:
    minutes: 10
    service: homeassistant.turn_on
    entity_id: switch.nc_tv_power
Here is my all configuration:
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 53.175
longitude: 17.6167
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 107
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time$
time_zone: Europe/Warsaw
customize:
binary_sensor.motionsensor:
friendly_name: “MotionSensor”
device_class: “motion”
sensor.dht_sensor_humidity:
friendly_name: “Upstairs_Wilgotnosc”
homebridge_hidden: true
automation:
    platform: rpi_gpio
    to: ‘off’
    for:
    minutes: 10
Show links to resources in log and frontend
introduction:
Enables the frontend
Enables configuration UI
config:
http:
Uncomment this to add a password (recommended!)
api_password: raspberry
Uncomment this if you are using SSL or running in Docker etc
base_url: example.duckdns.org:8123
Checks for available updates
updater:
Discover some devices automatically
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time.
View all events in a logbook
logbook:
Track the sun
sun:
Weather Prediction
binary_sensor:
  • platform: rpi_gpio
    device_class: motion
    ports:
    17: MotionSensor
  • platform: dht
    sensor: DHT11
    pin: 4
    monitored_conditions:
    • temperature
    • humidity
  • platform: broadlink
    host: 192.168.8.127
    mac: B4:43:0D:38:48:C6
    • temperature
switch:
platform: broadlink
host: 192.168.8.126
switches:
tv_phillips:
friendly_name: ‘Tv Power’
command_on: 'JgDaAJKTEjcTNhY0FRATEhEUERMTEhI3EzcUNBMTERQQExMTERMRExM2ExMRFBETEhISExEUETcWDhQ2EjgRNxM2EzcSNxMABfqTkxM2FDYSNxMTERMSExISEhQRNxI3EjcUEhISExIRExITEhQSNRIUEhITEhIU$
command_off: JgDaAJKTEjcTNhY0FRATEhEUERMTEhI3EzcUNBMTERQQExMTERMRExM2ExMRFBETEhISExEUETcWDhQ2EjgRNxM2EzcSNxMABfqTkxM2FDYSNxMTERMSExISEhQRNxI3EjcUEhISExIRExITEhQSNRIUEhITEhIU$
nc_tv:
friendly_name: ‘NC Tv Power’
command_on: JgBQAAABLJQTNhM3FDcTExISExETEhM3ExITNhQ3FDYUOBISFDcSExMSEjcTExETEjcUEhMSExISNhYREjYUNxMUETcTOBM2FAAFAwABLEoSAA0FAAAAAAAAAAA=
command_off: JgBQAAABLJQTNhM3FDcTExISExETEhM3ExITNhQ3FDYUOBISFDcSExMSEjcTExETEjcUEhMSExISNhYREjYUNxMUETcTOBM2FAAFAwABLEoSAA0FAAAAAAAAAAA=
Just looking at your automation, you need to change platform: rpi_gpio to platform: state
Thanks a lot, now it’s showing in Menu. I will try it and let know if it works :wink:
My pleasure. I hope it does the trick :slight_smile:
