Turn single led on when switch gets turned on
I installed a 4 channel relay in a box and i want to have an indicator light to turn on when each of the relay channels gets toggled on. I have 4 leds, 1 for each channel. They are red leds which are already soldered to 1k resistors. I can already make it work through an automation in esphome, but i’m sure there is a better way to do this. I am using an esp32s, a 4 channel relay, 4 solenoid valves with flyback diodes installed and a 12v psu plus the 4 leds in question.
I thought this code would work but the led still dont light up… I see both the led and the switch toggle get activated and turned off on the "esp32s web server page but no light is happening…
esphome:
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: "Netgear_dd"
  password: ~~~~~~~~~~~~~~~~
  ap:
    ssid: "Relay4Ch 01 Fallback Hotspot"
captive_portal:
web_server:
  port: 80
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: ~~~~~~~~~~~~~~~~~~
ota:
switch:
  - platform: gpio
    pin: 25
    inverted: true
    icon: mdi:sprinkler
    on_turn_on:
      then:
        - light.turn_on: led1
    on_turn_off:
      then:
        - light.turn_off: led1
  - platform: gpio
    pin: 26
    inverted: true
  - platform: gpio
    pin: 27
    inverted: true
output:
  - platform: ledc
    pin: GPIO33
  - platform: ledc
    pin: GPIO32
  - platform: ledc
    pin: GPIO14
light:
  - platform: monochromatic
    output: gpio_32
    output: gpio_33
    output: gpio_14
I’m sure it’s a little detail i didn’t see or something stupid… been trying to do this for months now
Thanks in advance
What is the ledc output brightness set to?
Try:
    on_turn_on:
      then:
          brightness: 100%
