I’m looking for an audio receiver with an audio out (XLR preferred, but could also use 3.5mm or RCA) so that I can turn my existing DJ speakers in the kitchen, into a media player that home assistant can control.
I’ve tried running a cable from the host and used vlc-telnet, but the audio breaks up badly (There are many hits on this topic on google),l so I am looking for a hardware alternative.
You could maybe use an “spare/old” mobile-phone, connect to it from HA through wifi or bluetooth, or maybe even homeassistant-APP installed … If the speakers is 4ohms, or a cellphone is enough to “power” the sound ( i-e like they can for most “pc-speakers” )
well, that depend on the way you choose i guess, if you install/integrate a media player in HA, which i haven’t and don’t use HA for, so can’t say anything in regards how that/they works, with output-options,
if you install mediaplayer on your phone, which i would have chosen as option_1, then i assume either bluetooth or wifi “autodiscover” would find it as “media_player”
I privious notised that AIMP is available through HACS, maybe that’s an option, as mentioned i haven’t tried VLS or any other options either
But a mobil phone, have wifi and bluetooth, and options to even install ha-app …
Your “Dumb speaker” is no longer “Dumb” when you connect to a mobile phone, as you can control the music app on your phone from another phone, or windows etc … and somehow also from HA … sorry my HA instance is not for media-players, so , i’ve already “disabled” my 2 android TV’s, when they popped up as media-player/google_cast devices, same for my regular phone( which i basicly use for what it is intended for, calls/ 2-factor-auth/ txt , and i use an old phone in the basement/laundry-room connected to harman.JBL soundbar, only for music purpose
So, in the end it was a bit of a combo solution.
Browser mod, running on the android tablet would not enable the media player entity, which was the only reason i wanted it!
I think its related to this issue:-
But I couldn’t find a solution.
so I ended up installing a dlna media receiver app on the tablet instead, and am sending audio to it that way. So far it seems to work flawlessly.
There are a few options out there, like airscreen and bubbleupnp for example.
its also worth noting that I also tried installing a DNLA media receiver on the same pc as home assistant, but it also suffered the same problems as vlc-telnet in that the audio broke up. I can only assume its because HA is running on virtualbox on a windows 11 host, and neither the host or HA can’t get full control of the audio device as its shared with the windows host.
i prefer AIMP, more “simple” , but i like it’s equalizer and the sound quality, there’s a version in HA, via HACS, and by default an Android and windows version. and monkey-remote works with it also
There’s an Android app that’s based on Airplay here:
edit: I gave it a go. It detects as an Apple TV 2 but refuses to play anything as pyatv makes the assumption it should be listening on port 5000, when it’s actually on 8192.
