Turning off RPi Power LED (Cronjob?)
Hey there,
I’m trying to disable the RPi 2B Power LEDs. In general, this is possible by executing
echo 0 >/sys/class/leds/led0/brightness
But as I’m using Hass.io with HassOS, I’m not able to run such a command. Is it possible to disable the Power LEDs anywhere else or is it possible to run this command? I would even prefer to run it as a cronjob after system start, would that be possible?
Regards,
Lars
Did you ever get an answer to this? I’d like to disable the power led and maybe the activity too. If we can save a few dozen milliamps, it makes a battery supply last longer! :smiley:
Thanks,
Ambi
