Tuxedo Touch Controller with HA
Try making your MAC address line:
mac: a22axxxxxxxx
I’m looking at setting up this integration
Could someone please let me know which branch to use, which has all the latest changes :confused:
Did you ever get this working ?
I’m having the same issue
I’ve used the ‘dev’ branch, and the code at 262 is now at 301
Placed the card in a restriction card (search HACS), added some protection, just make sure the tablet is logged as a user with no admin privileges.
type: custom:restriction-card
restrictions:
  pin:
    code: XXXXXXX
card:
  type: alarm-panel
  states:
    - arm_home
    - arm_away
    - arm_night
  entity: alarm_control_panel.tuxedo
Good to know, thanks
Has anyone managed to add an enttity_id to this connection so that it can be used in automations?
Or is anyone using the tuxedo touch in automations?
I continue to have problems getting this to work. Similar errors to above. I have tried the code modifications suggested on the original ‘draft’ code and the dev branch of code given by hinzo’s github.
Any suggestions on something I might be overlooking?
EDIT: Now working with below code. From linked branch and code edits from post ~29. Pretty sure I had already tried this once but maybe I didn’t restart at the correct time.
"""Interfaces with Tuxedo control panel."""
import asyncio
import base64
from datetime import timedelta
from hashlib import sha1
import hmac
import json
import logging
import random
import re
import urllib
from Crypto.Cipher import AES
from Crypto.Util.Padding import pad, unpad
from aiohttp.hdrs import CACHE_CONTROL, PRAGMA
import requests
import voluptuous as vol
import homeassistant.components.alarm_control_panel as alarm
from homeassistant.components.alarm_control_panel import (
    PLATFORM_SCHEMA as PARENT_PLATFORM_SCHEMA,
from homeassistant.components.alarm_control_panel.const import (
    SUPPORT_ALARM_ARM_AWAY,
    SUPPORT_ALARM_ARM_HOME,
    SUPPORT_ALARM_ARM_NIGHT,
from homeassistant.const import (
    CONF_CODE,
    CONF_MAC,
    CONF_NAME,
    CONF_URL,
    STATE_ALARM_ARMED_AWAY,
    STATE_ALARM_ARMED_HOME,
    STATE_ALARM_ARMED_NIGHT,
    STATE_ALARM_ARMING,
    STATE_ALARM_DISARMED,
    STATE_ALARM_PENDING,
    STATE_UNAVAILABLE,
from homeassistant.core import callback
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.event import async_track_time_interval
_LOGGER = logging.getLogger(__name__)
DEFAULT_NAME = "Tuxedo"
REGISTER_INTERVAL = timedelta(minutes=30)
CONF_PRIVATE_KEY = "private_key"
API_REV = "API_REV01"
API_BASE_PATH = "/system_http_api/" + API_REV
STATUS_MSG_ARMED_STAY = r"Armed Stay"
STATUS_MSG_ARMED_AWAY = r"Armed Away"
STATUS_MSG_ARMED_INSTANT = r"Armed Instant"
STATUS_MSG_DISARMED = r"Ready To Arm"
STATUS_MSG_TIMER = r"\d\s? Secs Remaining"
STATUS_MSG_NOT_AVAILABLE = r"Not available"
STATUS_MSG_NOT_READY = r"Not Ready Fault"
ARMING_NAME_STAY = "STAY"
ARMING_NAME_AWAY = "AWAY"
ARMING_NAME_NIGHT = "NIGHT"
PLATFORM_SCHEMA = PARENT_PLATFORM_SCHEMA.extend(
        vol.Required(CONF_URL): cv.string,
        vol.Required(CONF_MAC): cv.string,
        vol.Required(CONF_PRIVATE_KEY): cv.string,
        vol.Optional(CONF_CODE): cv.positive_int,
        vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
requests.packages.urllib3.util.ssl_.DEFAULT_CIPHERS = 'ALL:@SECLEVEL=1'
def setup_platform(hass, config, add_entities, discovery_info=None):
    """Set up Tuxedo control panel."""
    name = config.get(CONF_NAME)
    code = config.get(CONF_CODE)
    mac = config.get(CONF_MAC).replace(":", "-")
    private_key = config.get(CONF_PRIVATE_KEY)
    url = config.get(CONF_URL)
    tuxedo = TuxedoPanel(name, code, mac, private_key, url)
    add_entities([tuxedo], True)
def _sign_string(value, secret_key):
    return hmac.new(bytes(secret_key, "utf-8"), bytes(value, "utf-8"), sha1).hexdigest()
def _encrypt_data(data, key_string, iv_string):
    key = bytes.fromhex(key_string)
    iv = bytes.fromhex(iv_string)
    encryptor = AES.new(key, AES.MODE_CBC, IV=iv)
    cipher = encryptor.encrypt(pad(data, 16))
    return str(base64.b64encode(cipher), "utf-8")
def _decrypt_data(data, key_string, iv_string):
    raw = base64.b64decode(data)
    decrypted = unpad(encryptor.decrypt(raw), AES.block_size)
    return str(decrypted, "utf-8")
class TuxedoPanel(alarm.AlarmControlPanelEntity):
    """The Tuxedo panel definition."""
    def __init__(self, name, code, mac, private_key, url):
        """Initialize the Tuxedo status."""
        self._name = name
        self._code = str(code) if code else None
        self._mac = mac
        self._api_key_enc = private_key[0:64]
        self._api_iv_enc = private_key[64:]
        self._url = url
        self._state = STATE_ALARM_PENDING
    async def async_added_to_hass(self):
        """Hookup registration callback."""
        @callback
        async def async_register(event_time=None):
            result = await self._api_register(self._mac)
            _LOGGER.info("register result: %s", result)
        await async_register()
        async_track_time_interval(self.hass, async_register, REGISTER_INTERVAL)
    @property
    def name(self):
        """Return the name of the device."""
        return self._name
    @property
    def code_format(self):
        """Regex for code format or None if no code is required."""
        if self._code is None:
            return alarm.FORMAT_NUMBER
        return None
    @property
    def should_poll(self):
        """We only support polling."""
        return True
    @property
    def state(self):
        """Return the state of the device."""
        return self._state
    @property
    def supported_features(self) -> int:
        """Return the list of supported features."""
        return SUPPORT_ALARM_ARM_HOME | SUPPORT_ALARM_ARM_AWAY | SUPPORT_ALARM_ARM_NIGHT
    async def async_update(self):
        state = None
        result = await self._api_get_state()
        if result:
            _LOGGER.info("update result: %s", result)
            status_msg = result["Status"]
            if re.search(STATUS_MSG_DISARMED, status_msg):
                state = STATE_ALARM_DISARMED
            elif re.search(STATUS_MSG_ARMED_STAY, status_msg):
                state = STATE_ALARM_ARMED_HOME
            elif re.search(STATUS_MSG_ARMED_AWAY, status_msg):
                state = STATE_ALARM_ARMED_AWAY
            elif re.search(STATUS_MSG_ARMED_INSTANT, status_msg):
                state = STATE_ALARM_ARMED_NIGHT
            elif re.search(STATUS_MSG_TIMER, status_msg):
                state = STATE_ALARM_ARMING
            elif re.search(STATUS_MSG_NOT_AVAILABLE, status_msg) or re.search(
                STATUS_MSG_NOT_READY, status_msg
                state = STATE_UNAVAILABLE
        else:
            _LOGGER.error("couldn't fetch status")
        self._state = state
    async def async_alarm_disarm(self, code=None):
        """Send disarm command."""
        await self._api_disarm_request(code)
    async def async_alarm_arm_away(self, code=None):
        """Send arm away command."""
        await self._api_arm_request(ARMING_NAME_AWAY, code)
    async def async_alarm_arm_home(self, code=None):
        """Send arm home command."""
        await self._api_arm_request(ARMING_NAME_STAY, code)
    async def async_alarm_arm_night(self, code=None):
        """Send arm night command."""
        await self._api_arm_request(ARMING_NAME_NIGHT, code)
    async def _api_register(self, mac):
        return await self._async_api_request(
            "/Registration/Register", {"mac": mac, "operation": "set"}
    async def _api_get_state(self):
        return await self._async_api_request("/GetSecurityStatus", {"operation": "get"})
    async def _api_disarm_request(self, code=None):
        result = await self._async_api_request(
            "/AdvancedSecurity/DisarmWithCode",
            {"pID": "1", "ucode": code or self._code, "operation": "set"},
        _LOGGER.info("api_disarm_request result: %s", result)
        if result:
            await asyncio.sleep(2)
            self.async_schedule_update_ha_state()
    async def _api_arm_request(self, arm_name, code=None):
            "/AdvancedSecurity/ArmWithCode",
                "arming": arm_name,
                "pID": "1",
                "operation": "set",
        _LOGGER.info("api_arm_request %s result: %s", arm_name, result)
        if result:
    async def _async_api_request(self, api_name, params):
        return await self.hass.async_add_executor_job(
            self._api_request, api_name, params
    def _api_request(self, api_name, params):
        uri_params = urllib.parse.urlencode(params)
        _LOGGER.info("api_name: %s, uri_params: %s", api_name, uri_params)
        uri_params_encrypted = _encrypt_data(
            bytes(uri_params, "utf-8"), self._api_key_enc, self._api_iv_enc
        full_url = self._url + API_BASE_PATH + api_name
        header = "MACID:" + self._mac + ",Path:" + API_REV + api_name
        authtoken = _sign_string(header, self._api_key_enc)
        response = requests.post(
            full_url,
            data={
                "param": uri_params_encrypted,
                "len": len(urllib.parse.quote_plus(uri_params_encrypted)),
                "tstamp": random.random(),
            headers={
                "authtoken": authtoken,
                "identity": self._api_iv_enc,
                "PRAGMA": "no-cache",
                "CACHE_CONTROL": "no-cache",
            verify=False,
        result = None
        if response.status_code == 200:
            content = json.loads(response.content)
            result = _decrypt_data(
                content["Result"], self._api_key_enc, self._api_iv_enc
            result = json.loads(result)
        elif response.status_code == 401:
            # Unauthorized
            _LOGGER.error("Unauthorized, API: %s", api_name)
        elif response.status_code == 405:
            # Method Not Allowed
            _LOGGER.error("Method Not Allowed, API: %s", api_name)
        else:
            # Unknown
            _LOGGER.error(
                "Unknown error, status_code: %s, API: %s",
                response.status_code,
                api_name,
        return result
I’ve tried the latest code, but it errors out because the SSL certificate that Honeywell uses is super old and expired (2019)
I am using HAOS version:
Home Assistant 2023.5.2
Supervisor 2023.04.1
Operating System 10.1
Error:
ssl.SSLError: [SSL: UNSAFE_LEGACY_RENEGOTIATION_DISABLED] unsafe legacy renegotiation disabled (_ssl.c:1007)
Try the changes listed here: Tuxedo Touch Controller with HA - #31 by par-texx
I have the same issue. Already have the changes suggested by @par-texx.
Did you managed to get it working? 2023.5.3 didn’t make a difference too.
Ok, so when I finally got around to upgrading HA I’m having the issue as well.
From what I can tell, it’s as @caudex mentioned, it’s just a really old cert and urllib3 just killed the ability to talk to those certs.
So it’s not an HA thing, it’s an underlying library problem.
Except there is no easy way to fix it. I spent a few hours on it last night and got nowhere. I’ll keep trying this week.
The “verify=False” should have told the system to ignore bad certs, but it’s not working as expected.
I’ll keep plugging away at this, but I suspect I’ll have to remove the “response = requests.post(” section and rewrite it using urllib3 instead of requests…
Yeah, I’m not able to fix this. I have way too many other projects going on, so I"m looking at alternatives.
Ok, so I went and bought an Envisalink module and got that installed.
Way easier then using this code. I think we can consider this code dead and just move on.
Reinvigorating this thread. I feel like I’ve done everything right. Files are in tuxedo folder under custom components, lines of code in configuration.yanl (including removal of colons from MAC address), but no alarm entities are showing up in my entities list. Anyone with any idea what I might be doing wrong?
I never got mine working, and not I think the Tuxedo has died, so have not even gone back to look at this one :frowning:
The following code should work:
