Tuya 2-Gang Switch - Multiple Switch Type?
Hello everybody,
I started playing around with HA and Zigbee devices, and I recently purchased a new 2-Gang smart switch from Aliexpress (here the link: https://it.aliexpress.com/item/1005003417422886.html?spm=a2g0o.order_list.order_list_main.28.4e7a3696Fu1nsu - It is the 2CH Switch Module). I installed this module in my house; each output is connected to a different light (L1, L2) and also to a physical switch (S1, S2).
I managed to add the module correctly in HA using Zigbee2Mqtt and it is appearing in the related UI as model TS0002. I can also toggle the state of both switches from HA, which is fine. However, I see that there is only one setting for “Switch Type” which is applied to both outputs, see below screenshot:
In my setup I need to have a different switch type for each output, since my physical switches are configured differently in my house (S1 is a momentary switch connected to light L1, while S2 is a toggle switch connected to L2 light).
Is there a way I can setup a different switch type for each output?
Thanks in advance for the help!
