blueprint:
domain: automation
name: Moes/Tuya 4-Button Scene Switch by Dameq
description: Moes/Tuya 4-Button Scene via Zigbee (MQTT trigger version).
input:
input_device:
description: Select the Moes/Tuya 4-Button Scene Switch device
selector:
device:
integration: mqtt
manufacturer: Tuya
multiple: false
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 (top-left) single press
default: []
selector:
action: {}
button_one_double_press:
name: Double Press - Button 1
description: Action to run on button 1 (top-left) double press
default: []
selector:
action: {}
button_one_long_press:
name: Long Press - Button 1
description: Action to run on button 1 (top-left) long press
default: []
selector:
action: {}
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 (top-right) single press
default: []
selector:
action: {}
button_two_double_press:
name: Double Press - Button 2
description: Action to run on button 2 (top-right) double press
default: []
selector:
action: {}
button_two_long_press:
name: Long Press - Button 2
description: Action to run on button 2 (top-right) long press
default: []
selector:
action: {}
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 (lower-left) single press
default: []
selector:
action: {}
button_three_double_press:
name: Double Press - Button 3
description: Action to run on button 3 (lower-left) double press
default: []
selector:
action: {}
button_three_long_press:
name: Long Press - Button 3
description: Action to run on button 3 (lower-left) long press
default: []
selector:
action: {}
button_four_short_press:
name: Single Press - Button 4
description: Action to run on button 4 (lower-right) single press
default: []
selector:
action: {}
button_four_double_press:
name: Double Press - Button 4
description: Action to run on button 4 (lower-right) double press
default: []
selector:
action: {}
button_four_long_press:
name: Long Press - Button 4
description: Action to run on button 4 (lower-right) long press
default: []
selector:
action: {}
mode: parallel
max_exceeded: silent
- id: button_one_short_event
device_id: !input input_device
domain: mqtt
type: action
subtype: 1_single
trigger: device
- id: button_one_double_event
domain: mqtt
type: action
subtype: 1_double
trigger: device
- id: button_one_long_event
domain: mqtt
type: action
subtype: 1_hold
trigger: device
- id: button_two_short_event
domain: mqtt
type: action
subtype: 2_single
trigger: device
- id: button_two_double_event
domain: mqtt
type: action
subtype: 2_double
trigger: device
- id: button_two_long_event
domain: mqtt
type: action
subtype: 2_hold
trigger: device
- id: button_three_short_event
domain: mqtt
type: action
subtype: 3_single
trigger: device
- id: button_three_double_event
domain: mqtt
type: action
subtype: 3_double
trigger: device
- id: button_three_long_event
domain: mqtt
type: action
subtype: 3_hold
trigger: device
- id: button_four_short_event
domain: mqtt
type: action
subtype: 4_single
trigger: device
- id: button_four_double_event
domain: mqtt
type: action
subtype: 4_double
trigger: device
- id: button_four_long_event
domain: mqtt
type: action
subtype: 4_hold
trigger: device
- variables:
command: "{{ trigger.id }}"
- choose:
- conditions:
- "{{ command == 'button_one_short_event' }}"
sequence: !input "button_one_short_press"
- conditions:
- "{{ command == 'button_one_double_event' }}"
sequence: !input "button_one_double_press"
- conditions:
- "{{ command == 'button_one_long_event' }}"
sequence: !input "button_one_long_press"
- conditions:
- "{{ command == 'button_two_short_event' }}"
sequence: !input "button_two_short_press"
- conditions:
- "{{ command == 'button_two_double_event' }}"
sequence: !input "button_two_double_press"
- conditions:
- "{{ command == 'button_two_long_event' }}"
sequence: !input "button_two_long_press"
- conditions:
- "{{ command == 'button_three_short_event' }}"
sequence: !input "button_three_short_press"
- conditions:
- "{{ command == 'button_three_double_event' }}"
sequence: !input "button_three_double_press"
- conditions:
- "{{ command == 'button_three_long_event' }}"
sequence: !input "button_three_long_press"
- conditions:
- "{{ command == 'button_four_short_event' }}"
sequence: !input "button_four_short_press"
- conditions:
- "{{ command == 'button_four_double_event' }}"
sequence: !input "button_four_double_press"
- conditions:
- "{{ command == 'button_four_long_event' }}"
sequence: !input "button_four_long_press"
Hello dameq1,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
