Hi there,
I’m currently searching for a ceiling light, which can work with home assistant.
I found these ceiling lights on Aliexpress:
https://www.aliexpress.com/item/1005006861681827.html
There is a zigbee and a wifi version. The zigbee version should work with my ZHA network.
But in the future I want to flash the light with the ESPHome/OpenBeken firmware.
Does someone know, if this light can be flashed? I was not able to find it in the database.
And if yes, should I rather order the wifi or the zigbee version? Can the zigbee version be flashed with alternative firmware as well?
