Tuya climate integration - limit temperature range
Hi all, I’m at the end of my patience :slight_smile:
I have a climate controller intergrated via Tuya in HA.
The damned thing looks (almost) ok in Tuya, showing the maximum temperature as 50 degrees Celsius (also bad, but seems cooler than 300 C). But in Home Assistant, the card shows the maximimum temperature as 300 degrees Celsius, as if it wants to cook me.
For months I’ve tried in my spare time to find a workaround, trying either to configure something in Tuya to limit the temperature, something in HA confis (like DEFAULT_MAX_TEMP = 35), Tuya integration, or even only on the card to limit to let’s say 30 degrees.
Any ideas?
The only thing I can think of is to create a generic thermostat that controls the tuya thermostat
