I have been using the Tuya integration for months now and on this last Home Assistant update 2023.3.6, something has changed. I have full control of the light with the Smart Life App. Home Assistant can control the light by changing the color. I can see the change in the app. However every time I change the color in Home Assistant via the color wheel, the brightness goes down to 0%. Also the slider for Home assistant no longer controls the brightness at all. Again I can control everything on the light via the app, but Home Assistant has lost control of the brightness. Is anyone else seeing this? Any suggestions on a fix?
I seem to be getting this message all of a sudden when I try and change the brightness:
failed to call service light/turn_on. value must be at least 1 for dictionary value @ data[‘color_temp’]
