Did you ever get this working?. I have purchased one and just waiting for it to arrive.
@nsacras I notice the unit you have posted pictures of seems to have a Silicon Labs EFR32 chip and not the ESP8266 chip on it like the one @hollenburg has. I think to flash tasmota you need the ESP8266. Is yours a zigbee unit?
yes it works. There is an esp8266 inside.
After 20-30 attempts with tuya flush and a lot of patience.
It seems to be an old version from 2018 without temperature and humidity measurement. And without zigbee.
I received another module that seems newer.
Let’s see how that works.
I will report.
Hi, I bought 2 of neo coolcam siren and sucessfully flash tasmota with tuya convert. TYA: MCU Product ID: {"p":"ymf4oruxqx0xlogp","v":"1.0.2","m":0} is the version of my device. I followed your guide using the template adn backlog command after it reboot I have the toggle button on the main menu. click on the toggle button only turn on or off the flashing led on the top of the device. I tried on my second device with the same result. what shoud I do to have the device working as it should be.
Please Help…
Sorry for your inconvenient. I’m not really sure what happen but after I setup mqtt connection to the device then it working as expected. not really sure it is related or not.
I having an issue on humidity reading. the value report is very low which is not correct.
how can I get correct value or at least close to what it should be from the device.
This is working flawlessly. However, I’m able to manually set a siren duration much higher than what Home Assistant is allowing me.
Currently, the slider is allowing a max of 60 seconds, and with the console, I can use TuyaSend2 103,120 or more, any way I can fix this in Home Assistant to allow automations to set the duration higher?
I keep getting this error when I try changing the entities maximum value, I’m fairly new to Home Assistant (couple of months so any help would be great)
Failed to call service number/set_value. Value 120.0 for Siren_1 Alarm Duration is outside valid range 1.0 - 60.0
Hey Guys, I have used the configuration on the tasmota page for the siren, however I always get this error : The system cannot restart because the configuration is not valid: Invalid config for [sensor.mqtt]: [command_topic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->command_topic. (See ?, line ?).
Here is the config pasted from tasmota :
platform: mqtt
name: Siren Power Status
state_topic: siren/battery
value_template: >-
{% if value == ‘1’ %}
high
{% elif value == ‘2’ %}
medium
{% elif value == ‘3’ %}
low
{% elif value == ‘4’ %}
USB
{% endif %}
icon: ‘mdi:power-plug-outline’
availability_topic: tele/siren/LWT
payload_available: Online
payload_not_available: Offline
platform: mqtt
name: Siren Alarm Volume
state_topic: siren/alarmvolume
value_template: >-
{% if value == ‘0’ %}
high
{% elif value == ‘1’ %}
medium
{% elif value == ‘2’%}
low
{% endif %}
icon: ‘mdi:volume-vibrate’
platform: mqtt
state_topic: “%topic%/chime”
command_topic: “cmnd/%topic%/event”
value_template: >-
{% if value == “0” %}
Doorbell
{% elif value == “1” %}
Fur Elise
{% elif value == “2” %}
Big Ben
{% elif value == “3” %}
Ring Ring
{% elif value == “4” %}
Lone Ranger
{% elif value == “5” %}
Turkish March
{% elif value == “6” %}
High Pitched
{% elif value == “7” %}
Red Alert
{% elif value == “8” %}
Crickets
{% elif value == “9” %}
Beep
{% elif value == “10” %}
Dog Bark
{% elif value == “11” %}
Police Siren
{% elif value == “12” %}
Grandfather Clock
{% elif value == “13” %}
Phone Ring
{% elif value == “14” %}
Fire Truck
{% elif value == “15” %}
Clock Chime
{% elif value == “16” %}
Alarm Clock
{% elif value == “17” %}
School Bell
{% endif %}
options: [“Doorbell”,“Elise”,“Big Ben”,“Ring Ring”,“Lone Ranger”,“Turkish March”,“High Pitched”,“Red Alert”,“Crickets”,“Beep”,“Dog Bark”,“Police Siren”,“Grandfather Clock”,“Phone Ring”,“Fire Truck”,“Clock Chime”,“Alarm Clock”,“School Bell”]
icon: “mdi:music-note”
availability_topic: “tele/siren/LWT”
payload_available: “Online”
payload_not_available: “Offline”
Thank you very much for all the work you have put in! This stuff is probably straight forward but spent countless nights trying to get this siren to work. I have managed to flash and able to see the mqtt diagnostics entities and temp/humidy. For the life of me I cannot get the others to work.
I think the details on the template website must be out of date with latest HA and/or Tasmota?.
I’m running the latest version of HA/HASSOS (2022.2.9 & 7.4) and also Tasmota (10.1) on this device.
I get the same error as @chrisground when I add the configuration.yaml components from the template website.
Having said that it appears it’s not even necessary to add that at all if you install the blueprint as the YAML appears to just make MQTT replicas of what the blueprint is creating on the siren entity, so If I install the blueprint only I get the following show up:
The problem I have is that I can’t see the Temp or Humidity. They don’t appear at all on the entity list for this siren with the blueprint installed, so I thought perhaps the issue was my siren is incorrect and I don’t have those sensors on it but If I change ‘Rule3’ to the following:
rule3 on tuyareceived#dptype2id105 do publish %topic%/temp %value% endon on tuyareceived#dptype2id106 do publish %topic%/humidity %value% endon on tuyareceived#dptype2id103 do publish %topic%/alarmduration %value% endon on var1#state do tuyasend2 103,%value% endon on tuyareceived#dptype4id101 do publish %topic%/battery %value% endon on tuyareceived#dptype4id102 do publish %topic%/chime %value% endon on tuyareceived#dptype4id116 do publish %topic%/alarmvolume %value% endon on var6#state do tuyasend4 116,%value% endon
I can then see TEMP and HUMIDITY values show up in the Tasmota console of the device and are published as MQTT messages to HA.
So I’m wondering if the blueprint can simply be updated to show those two sensors and we can remove the YAML completely?. I assume I should then just be able to install the blueprint and get total control of the device with all sensors?
So all I used was the blueprint in the end and no changes to the YAML
I think for some reason some of the config options did not stick when I setup the device. I noticed in the picture @dexstar posted that he had the temp and humidity values present in the Tasmota GUI, but on mine they were not there. After I reapplied all the the TuyaMCU commands in the template they showed up, and after checking in the HA entities list the sensors are now showing
