i used the iot.tuya integration to add my tuya devices.
one of them is a curtain with light
https://www.aliexpress.com/item/1005002697690566.html?spm=a2g0o.order_list.order_list_main.150.7d2e586aWQ4u9U&gatewayAdapt=glo2isr
i can see in the devices both curtain and light
curtain works fine where the light does not response.
also looked in the logs and found the following request:
2023-10-14 14:43:56.107 DEBUG (SyncWorker_4) [homeassistant.components.tuya] Sending commands for device someId: [{'code': <DPCode.SWITCH_BACKLIGHT: 'switch_backlight'>, 'value': True}]
2023-10-14 14:43:56.107 DEBUG (SyncWorker_4) [tuya_iot] Request: method = POST, url = https://openapi.tuyaeu.com/v1.0/devices/someId/commands, params = None, body = {'commands': [{'code': <DPCode.SWITCH_BACKLIGHT: 'switch_backlight'>, 'value': True}]}, t = 1697283836107
2023-10-14 14:43:56.273 DEBUG (SyncWorker_4) [tuya_iot] Response: {
"result": true,
"success": true,
"t": 1697283836204,
"tid": "yyyyyyyyyyy"
can someone assist please?
