Hello Community,
I have a tasmotized Tuya dimmer using TuyaConvert. I wanted to give ESPhome a shot. I installed the addon and compiled the following:
esphome:
platform: ESP8266
board: esp01_1m
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
password: "3793e165a8b72b0534fcb1676a2d6770"
wifi:
ssid: "***"
password: "***"
ap:
ssid: "Csmartdim Fallback Hotspot"
password: "EATIN1f442vb"
captive_portal:
# My dimmer used the hardware serial port on the alternate pins
uart:
rx_pin: GPIO13
tx_pin: GPIO15
baud_rate: 9600
# Register the Tuya MCU connection
tuya:
The validation gives:
INFO Reading configuration /config/esphome/csmartdim.yaml...
INFO Configuration is valid!
esphome:
platform: ESP8266
board: esp01_1m
arduino_version: platformio/[email protected]
build_path: csmartdim
platformio_options: {}
esp8266_restore_from_flash: false
board_flash_mode: dout
includes: []
libraries: []
name_add_mac_suffix: false
logger:
baud_rate: 0
tx_buffer_size: 512
hardware_uart: UART0
level: DEBUG
logs: {}
esp8266_store_log_strings_in_flash: true
api:
port: 6053
password: ''
reboot_timeout: 15min
ota:
password: 3793e165a8b72b0534fcb1676a2d6770
safe_mode: true
port: 8266
reboot_timeout: 5min
num_attempts: 10
wifi:
ap:
ssid: Csmartdim Fallback Hotspot
password: EATIN1f442vb
ap_timeout: 1min
enable_mdns: true
domain: .local
power_save_mode: NONE
fast_connect: false
output_power: 20.0
networks:
- ssid: ***
password: ***
priority: 0.0
use_address: csmartdim.local
captive_portal: {}
uart:
- rx_pin: 13
tx_pin: 15
baud_rate: 9600
rx_buffer_size: 256
stop_bits: 1
data_bits: 8
parity: NONE
tuya: {}
I had some errors to migrate, but found out I had to downgrade my Tasmota version. Successfully migrated and added the device via ESPHome integration using the device IP.
My question is how to configure it? I have only only light switch in HA, but it doesn’t do any action on the device. The dimmer has on/off, increase and decrease button.
I followed the guide on Tuya Dimmer : Tuya Dimmer — ESPHome
It seems I needed to enable webserver to log to the device directly.
Can anyone provide some guidance please? Thank you.
