Trying to add a Tuya entity but keep running into an error saying Tuya failure, see log. Tuya has always worked fine until now. My existing entities still seem to work okay but I cannot add any new ones. Please I need help to fix this annoying problem.
Error from log as follows:
Logger: homeassistant.config_entries
Source: config_entries.py:769
First occurred: 2 April 2026 at 11:59:36 (19 occurrences)
Last logged: 07:44:44
Error setting up entry [email protected] for tuya
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 769, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/xtend_tuya/multi_manager/shared/decorator.py”, line 41, in wrapped
return_val = await self.orig_method(*args, **kwargs)
[Previous line repeated 3 more times]
File “/config/custom_components/xtend_tuya/multi_manager/shared/decorator.py”, line 45, in wrapped
await callback(
…<5 lines>…
File “/config/custom_components/xtend_tuya/multi_manager/managers/tuya_sharing/ha_tuya_integration/config_entry_handler.py”, line 50, in on_tuya_setup_entry
hass.config_entries.async_schedule_reload(self.config_entry.entry_id)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 2350, in async_schedule_reload
entry = self.async_get_known_entry(entry_id)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 2073, in async_get_known_entry
raise UnknownEntry(entry_id)
homeassistant.config_entries.UnknownEntry: 01KN78PHMCNDTJ6A4ESY981RGS
