Tuya gate opener
I had pre-used a tuya gate opener (https://a.aliexpress.com/_olbMxIH).
The gate controller is marked that it is not working with ZHA.
I switched to hone assistant and I am trying to connect this controller although the warning.
The device is recognized by HA but as expected I can’t open or close the gate.
Any ideas if I can use it or should I buy a different device?
Any device recommendations?
Get your device signature and see if there is a quirk in work. If not see My Tuya device doesn't work with ZHA - Or how to build a Tuya Quirk
Thank you. I’ll give it a try, will update
This may be a good starting quirk, Add Tuya TS0603 garage door module `_TZE608_fmemczv1` by rafmet · Pull Request #3607 · zigpy/zha-device-handlers · GitHub
