Tuya Heater shows as a switch instead of a climate entity
and to add… put a sonoff s31 in front of it to monitor power
These draw around 725w on LOW setting
I had this set up in the Tuya integration, but it’s disappeared. I’m wanting to just use Tuya local and I have my local Key and Device ID. Having a bit of an issue lining up the correct numbers to what they do. Does anyone have a print out from the IOT ingigration they can share as I remember seeing them there or anyone else who has used Tuya Local that can share how you configured each item?
After some research I found that if you install HACS (Home Assistant Community Store) and tell it to install a custom integration you can now add Tuya’s “Smart Life” integration manually. Someone had pointed out that Tuya v2 Beta was working and when I went to GitHub there was a message that Tuya was moving to the “Smart Life” version.
I have purchased two of the Heat Storm 1,500-Watt Wi-Fi Smart Heaters and am using the Smartlife app. However, I keep getting messages on the app about the remotes being removed due to a reset or something like that. Is there any way of getting rid of those messages that keep popping up? I appreciate any help. Thank you.
Have the same issue with the Tuya smart thermostat only showing up as a toggle switch.
Any ideas how to expose all entities for this device?
