Hi everyone! I have two issues I’m hoping to get help with.
First, I purchased the below energy monitors to monitor the energy used by my washer and dryer. At times, the data from the energy monitors does not seem to flow over to Home Assistant. I have to open the Tuya app and “wake up” the devices before I see energy readings. I did some research and another user stated that the HACS version of the Tuya integration solves this problem. Is this true or should I pursue another approach?
If HACS is recommended, I’m actually having a problem with HACS starting. I get the below error message and can’t seem to figure out the issue. I’ve removed it completely and reinstalled with no change. Any assistance with the error would be greatly appreciated! Thank you!
> Logger: homeassistant.config_entries
Source: config_entries.py:749
First occurred: June 2, 2025 at 10:18:40 PM (2 occurrences)
Last logged: 8:33:27 AM
Error setting up entry for hacs
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/hacs/__init__.py", line 246, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File "/config/custom_components/hacs/__init__.py", line 214, in async_initialize_integration
await async_try_startup()
File "/config/custom_components/hacs/__init__.py", line 201, in async_try_startup
startup_result = await async_startup()
File "/config/custom_components/hacs/__init__.py", line 170, in async_startup
async_register_frontend(hass, hacs)
File "/config/custom_components/hacs/frontend.py", line 68, in async_register_frontend
hass.components.frontend.async_register_built_in_panel(
AttributeError: 'HomeAssistant' object has no attribute 'components'
