This is the detailed log of the error I got yesterday, in case it helps someone. I’m too new to HA; it would take me quite some time to go further than this. I suspect that it has something to do with the latest change of certificate (in the GUI now, and I commented out the references to the certificates in the config.yaml file.)
2026-08-05 23:57:29.529 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546954534064] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 283, in handle_call_service
response = await hass.services.async_call(
...<7 lines>...
File "/usr/src/homeassistant/homeassistant/core.py", line 2961, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 3004, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 906, in entity_service_call
response_data = await _async_handle_entity_calls(
...<5 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 785, in _async_handle_entity_calls
single_result = await entity.async_request_call(_with_context(entity, coro))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1710, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 780, in _with_context
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 864, in _handle_single_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 529, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/switch_as_x/entity.py", line 158, in async_turn_off
await self.hass.services.async_call(
...<5 lines>...
...<5 lines>...
return await coro
return await coro
result = await task
File "/usr/src/homeassistant/homeassistant/components/tuya/switch.py", line 997, in async_turn_off
await self._async_send_wrapper_updates(self._dpcode_wrapper, False)
File "/usr/src/homeassistant/homeassistant/components/tuya/entity.py", line 107, in _async_send_wrapper_updates
await self._async_send_commands(
wrapper.get_update_commands(self.device, value),
File "/usr/src/homeassistant/homeassistant/components/tuya/entity.py", line 91, in _async_send_commands
await self.hass.async_add_executor_job(
self.device_manager.send_commands, self.device.id, commands
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 86, in run
result = ctx.run(self.task)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 73, in run
return fn(*args, **kwargs)
File "/usr/local/lib/python3.14/site-packages/tuya_sharing/manager.py", line 99, in send_commands
return self.device_repository.send_commands(device_id, commands)
File "/usr/local/lib/python3.14/site-packages/tuya_sharing/device.py", line 213, in send_commands
self.api.post(
f"/v1.1/m/thing/{device_id}/commands", None, {"commands": commands}
File "/usr/local/lib/python3.14/site-packages/tuya_sharing/customerapi.py", line 194, in post
return self.__request("POST", path, params, body)
File "/usr/local/lib/python3.14/site-packages/tuya_sharing/customerapi.py", line 119, in __request
raise ApiRequestException(error_code=ret["code"], error_message=ret["msg"])
tuya_sharing.exceptions.ApiRequestException: network error:(-9999999) sign invalid
